First post, by 386SX
Hi all,
I bought a Logilink PC0005a VT6421a sata card with two SATA and IDE connector on PCI bus to upgrade my Chaintech 5AGM2 mvp3 based s7 mainboard. The goal was to use a 64GB SSD 2.5" hd into it to speed up the whole system a bit.
In the manual it talk about booting to a os and then install the card but i obviously want to boot and install through it from boot, but setting SCSI boot on bios seems not to see the cdrom on ide and probably not also the hd on the sata connector.
Do I need some key combination to force at boot scsi boot or some sort of boot disk? Or the mainboard and chipset are just too old?
Bye and thank
