PCIe devices on Windows 98 SE
Reply 100 of 107, by Kamerat
xtreger wrote on 2024-01-03, 05:05:
Hi! I'm trying to do pretty much the same thing, but struggling. I have a P5KPL-AM/PS motherboard with an nVidia Geforce 7100 GS […]
Hi! I'm trying to do pretty much the same thing, but struggling. I have a P5KPL-AM/PS motherboard with an nVidia Geforce 7100 GS. For reference, this is the model I have: https://www.mercadopc.com/logic/servlet/item?iditem=196935.
RAM is 2 Gb, but I've used MaxFileCache=512000 and MaxPhysPage=30000 in system.ini, so that Windows detects around 700 Mb RAM. I installed Win98 SE normally, then used the unofficial nVidia 82.69 driver pack (NV8269.zip).
The GFX card gets autodetected but is extremely unstable and constantly gives the "The display adapter is not working/conflicts, etc. ... " sort of error. So in one boot I'm able to change the resolution to 16 bit with 640x480 res, but as soon as I try to change it to 32 bit with 1024x768 res, the PC flat out freezes. Next boot, it gives the above error and Win98 gets stuck after the username/password screen.
Since you've done this successfully @Kamerat, any pointers on another method to get 7100 GS working? From what I see, you used some official nVidia driver and it somehow worked for 7800 GTX. But how do I know which nVidia driver to use for my 7100 GS? And of course the autodetection won't happen, so how do I force the system to detect it?
You can try out RLoew's PatchMEM for Windows to behave better with larger amounts of RAM: http://vogonsdrivers.com/getfile.php?fileid=1814
The BurnMem utility is also an option. Added it as an attachment as old-dos.ru that hosted the file seems to be down.
    Burnmem.English.zip
    16.58 KiB
    23 downloads
YouTube channel
Reply 101 of 107, by xtreger
Kamerat wrote on 2024-01-03, 11:01:
Thank you so much! I tried patchmem as you said, and now all the instability is gone. The only remaining issue now is: I installed DX9 and ran 3Dmark01 SE on my PC with 7100 GS. It only gives around 6.6K score.
I would've expected a higher score because it's a later generation card, that too with PCIe. I tried both the 6800 GT driver under the Forceware 81.98 package, as well as the unofficial tweaked 82.69 nvidia's 7100 GS driver. Under both the drivers the 3Dmark01 score was 6.6k only. Any idea what I could be missing? (and thanks again for the patchmem tip)
Reply 102 of 107, by Kamerat
xtreger wrote on 2024-01-03, 12:36:
Your 7100 GS should be comparable to my entry for the "NVIDIA GeForce 6200 TurboCache(TM) (NV44) 256MB 64bit DDR2". Your number is about 85,5% of my result but CPU speed and system memory bandwidth/latency can also contribute to this lower number.
YouTube channel
Reply 103 of 107, by xtreger
Kamerat wrote on 2024-01-03, 13:14:
I see.. so with 7100 GS, at a maximum, I can get around 8000 3dmark 2001 score. With AGP GeForce 5200 FX I was getting around 6.5k or so. And 5200 FX is generally regarded as subpar. So I guess 7100 GS is not a very good card either. I'll see if I can find a GF 7600 or higher.
Reply 104 of 107, by SayakatheSnoo
Kamerat wrote on 2015-08-07, 02:31:
Here is a little list of PCIe devices that that I've tested successfully on Windows 98 SE, no special PCIe driver used. I've inc […]
Here is a little list of PCIe devices that that I've tested successfully on Windows 98 SE, no special PCIe driver used. I've included an updated NVAML.INF file for the NVIDIA cards with the 81.98 driver for autodetecting.
Testrig:
CPU: AMD Athlon 64 X2 4200+ @ 2,85GHz
RAM: DC 2x 512MB ECC @ 475MHz 5-5-5 2T
MB: ASRock 939Dual-SATA2
Graphic cards:
ATI Radeon X800 XT (R423) 256MB 256bit GDDR3
Device ID: 5d57
Driver: 6.2 (4.15.1.9165)
Driver autodetects: YES
3DMark 2001: 25188
ATI Radeon X800 XL (R430) 256MB 256bit GDDR3
Device ID: 554d
3DMark 2001: 24351
Device ID: 0161
Driver: 81.98 (4.14.10.8198)
Driver autodetects: NO
3DMark 2001: 7720
3DMark 2001: 10216 505MHz/715MHz
NVIDIA GeForce 6200SE TurboCache(TM) (NV44) 64MB 32bit DDR
Device ID: 0162
3DMark 2001: 4820
NVIDIA GeForce 6600 GT (NV43) 256MB 128bit DDR3
Device ID: 0140
3DMark 2001: 21064
NVIDIA GeForce 6800 GS (NV42) 256MB 256bit GDDR3
Device ID: 00c0
3DMark 2001: 24719
NVIDIA GeForce 7800 GTX (NV47/G70) 256MB 256bit GDDR3
Device ID: 0091
3DMark 2001: 28333
3DMark 2001: 29461 490MHz/1380MHz
Other devices:
JMicron JMB36X (SATAII controller)
Vendor ID: 197B
Device ID: 2360
Driver: 0.92
Comment: Using this for boot/Windows hard drive.
Will a 6600 without any suffix work? I just found one in the wild and hope to grab it for usage with my P4 build.
Reply 105 of 107, by Kamerat
SayakatheSnoo wrote on 2024-01-09, 03:20:
I don't think that would be a problem, still uses the same NV43 GPU.
YouTube channel
Reply 106 of 107, by przemek
Kamerat wrote on 2016-04-14, 16:10:
Got the ATI Mobility Radeon X700 PCIe working with an external monitor on an Asus A6000 series laptop (Pentium M 740, 512MB DDR2) using modified drivers scoring 15262 in 3DMark2001.
How did you modify the driver? I have x600 mobility radeon with rv380 core and want also run it on windows 98. I have successfully installed x300 mobility in other laptop because the drivers were in catalyst 6.2. There are also for x600 but for the desktop version. Did your x700 work only with external monitor, or also with the built in display ? Any help will be appreciated.
Reply 107 of 107, by Kamerat
przemek wrote on 2024-01-19, 09:40:
You can add the PCI ID of the card to the drivers INF file or just force installation.
I don't remember the details from when I tested the X700, but I think it only worked with an external monitor.
YouTube channel
