First post, by soviet conscript
I realized I had a Intel 486dx-50 last night and threw together a system for fun but I have a few questions. first do these benchmarks look about correct? I feel they are a tad on the slow side but I'm not really sure. Speedsys is marking it about as fast as a 486dx2-50 but I was assuming a DX at a 50mhz FSB would be a little faster. I'm using a FIC 486-GVT motherboard.
3Cbench - 39.3
PCPbench - 7.9
DOOM - 20.68
Quake - 4.9
Speedys - 18.85
also whats the difference when setting motherboards FSB between 50 and 50i? I usually see this for 50 and 66mhz settings with two separate options. I had to set mine to 50i since when I set the jumpers for 50 I got 33mhz. I assumed the i was for CPUs that used multipliers but mine is a regular DX so there's no way I'm getting 25X2 FSB right? The system is also suspiciously stable, not that that's a bad thing but it runs fine and I was expecting a lot of issues with a 50mhz FSB but then maybe I just lucked out with my VLB video card.
Reply 1 of 11, by vetz
Here are my DX50 results (submitted to Phils VGA database):
3Dbench - 31.5
PCPbench - 8.4
DOOM - 18.42
Quake - 5.1
Hardware:
Intel 486DX-50
AUVA CAM50-UO (UMC UM8498F chipset) (ISA only)
8MB RAM
ATI Mach32 2MB VRAM ISA
I'd say yours look very much on the spot.
Reply 2 of 11, by sliderider
With the DX-50 the fsb and the internal clock should both be 50mhz. A DX2-50 would be 25/50. I wouldn't build a DX-50 system, myself. Early boards that run at 50mhz are unstable and later boards that support 50mhz are better off with a faster 486 or 5x86 in them.
Reply 3 of 11, by soviet conscript
I agree but seeing as I already have several 486 systems built (33mhz, 66mhz, amd 5x86 133mhz and Crrix 120mhz 5x86) I thought a 50mhz machine would be a fun little project seeing as I already had a spare 66mhz PC just sitting around.
Reply 4 of 11, by kanecvr
vetz wrote:
Here are my DX50 results (submitted to Phils VGA database): 3Dbench - 31.5 PCPbench - 8.4 DOOM - 18.42 Quake - 5.1 […]
3Dbench - 31.5
PCPbench - 8.4
DOOM - 18.42
Quake - 5.1
Hardware:
Intel 486DX-50
8MB RAM
Seems on par with my DX50. How much do you get in speedsys?
Reply 5 of 11, by Anonymous Coward
Programs that can fit inside the CPU's internal cache will run at the same speed on the DX-50 and the DX/2-50. Software that is I/O intensive should get a pretty nice speed boost with the DX-50 (since in theory your memory throughput should be a lot higher). However, this is not always the case in practice. A lot of motherboards can't really handle 50MHz the way it was meant to be run and cheat by adding a bunch of extra wait states. On many of my SiS boards for example, tightly tuned 33MHz memory outperforms 50MHz memory with a bunch of wait states.
Still, VLB at 50MHz should be pretty bloody fast, especially if you can do it with 0WS.
Reply 6 of 11, by soviet conscript
hmmm, there is a jumper on the MB to set VESA wait states between 1 and 0 but I get the exact same bench numbers regardless of the setting. everything in BIOS is set to the turbo or fastest settings and so far its been completely stable
Reply 7 of 11, by soviet conscript
Vetz, does your l2 cache work ok at 50MHz fsb? Can anyone give an example of a game or program where the dx50 beats out the dx2-66? In every bench I run the dx2-66 smokes the dx50 in this setup.
Reply 8 of 11, by vetz
Yes, no issues encountered. I can't think of any at the moment. I've bought a DX2-66 Overdrive which will fit into this board so I can do a comparison.
Btw, if your DX-50 is running VLB I'd recon you would smoke my ISA VRAM based system.
Reply 9 of 11, by soviet conscript
Here's a video I did comparing a few cpus in the exact same machine. I don't think the l2 cache is running though with the dx50, cachechk crashes when I try and run it. Otherwise it runs fine. https://youtu.be/PHggOR-6Zig
Reply 10 of 11, by vetz
You do have 16 more mhz which may provide better results in 3DBench than increasing the FSB. Could be different in other benchmarks.
I currently dont have my DX50 system operational, so can't test this at the moment.
Reply 11 of 11, by sunaiac
A few reference values :
(MB1433/40/50 UIV-A rev 6, DC680T VLB cache controler, 32MB ram, ET4000/W32p VLB 😀 )
R9 3900X, X470 Taichi, 32GB 3600CL15, 5700XT AE, Marantz PM7005
FX-57/X1950XTX/Audigy 2ZS | Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
i7 980X/R9 290X/X-Fi titanium | Ppro 200 1M | Voodoo 3 2000 | AWE 32 | iDX4 100/S3 864 VLB/SB16
