First post, by brostenen
Hi all.
There is really a lot of talk about taking one fast system, and turning it into a 386/486 class machine by disabling cache on CPU/Mobo.
Now I am wondering. Wich exact system will give a DX2-66, when disabling CPU Cache only, and leaving the Mobo Cache enabled?
Reply 1 of 8, by boxpressed
I have a K6-3+ on an FIC VA-503+ (VIA MVP3). I run the CPU at 5.5x and 100 MHz. When I use SETMUL to change the multiplier to 2 and to disable the L1 cache, Speedsys gives me a rating that is similar to a 66 MHz 486.
Reply 2 of 8, by brostenen
Thanks. Yet I was more looking into just disabling L1 in order to get that performance.
Reply 3 of 8, by boxpressed
I have a KT133A system with an Athlon XP 2400+, and when the internal cache is disabled. Speedsys also gives me a rating close to a 66MHz 486.
Reply 4 of 8, by brostenen
Tried to disable L1 on my P133. It is somewhere around 486 25mhz to 50mhz.
Some benchmark tools say one thing, others say another.
Reply 6 of 8, by brostenen
oerk wrote:
Why? As long as the end result is the same, why do you care?
Because it is nice to have the numbers. Yeah... It's the same thing about GFX benchmarks.
Why know what cards that you don't own can crunch? Because it is nice to know.
Actually. Knowing these CPU numbers, are something that are not covered here on Vogons.
Well... Not extensively covered, as in making a database with as many CPU/Mobo combo's as possible.
Perhaps someone should make a chart, just as we have these GFX benchmark charts. 😁
Reply 7 of 8, by Agent of the BSoD
On my K6-III+ with FIC PA-2013, when I ran it at 100MHz at 4x multiplier and disabled L1, I got about DX2 50 speeds. Could probably get up to 66 by increasing the multiplier further.
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | SB Pro 2 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
Reply 8 of 8, by PhilsComputerLab
In all the cache experiments I did, and I did quite a few 😊 , I found that the DX2-66 performance is not obtainable. Even if you pick the fastest cache-less processors (MMX and Cyrix), I got up to a DX2-50 if I remember correctly. That is still pretty decent IMO.
EDIT: On that chart it looks very close. Maybe you can hit the speed, this was all years ago...
I found this older image of mine:
The black shaped area shows what speeds you cannot obtain with cache tricks on various processors.
YouTube, Facebook, Website
