First post, by computergeek92
ZIP 100 and 250 drives? And I shouldn't have a problem with a 386SX16 with a 3.5, 5.25 floppy drives all together in the same system? Also, how much better is Windows 3.0 vs DOS Shell?
Dedicated Windows 95 Aficionado for good reasons:
http://toastytech.com/evil/setup.html
Reply 3 of 14, by alexanrs
Windows 3.11, AFAIK, also does not have nor needs drivers for ZIP drives. Both 3.0 and 3.11 rely on DOS to access ZIP drives. Just install the DOS drivers and it will work on Windows 1/2/3/3.11.
Reply 4 of 14, by sliderider
Be very careful if you are using an external zip drive. Some are made for SCSI and some are made for parallel port and the connectors are mechanically the same but not electrically the same. Confusing the two would result in damage to the drive, the computer, or both.
Here's a photo of the two for comparison
Would you be able to tell which is which in the dark?
Reply 6 of 14, by SquallStrife
Pretty sure you install the DOS driver, and Windows just accesses it thru INT21h .
[retro swim] | Link | Release Thread
Regular silliness on Twitch!! http://www.twitch.tv/RetroSwim (8PM Mon, Wed, Sat AEST)
Reply 7 of 14, by Caluser2000
download the drivers and have a peak http://files.mpoli.fi/hardware/HDD/IOMEGA/
you can veiw the contents of each file on this page http://files.mpoli.fi/unpacked/hardware/hdd/iomega/
Reply 8 of 14, by dr.zeissler
palmzip is by far the best driver for a lpt-zip.
http://leute.server.de/peichl/palmzipe.htm
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
Reply 9 of 14, by computergeek92
Thanks a bunch! I'll try those drivers out once I get my hands on a 386SX 16 someday and have fun playing with the slowest 32-bit PC ever! 😁
Reply 10 of 14, by chinny22
Never new about palmzip, and just had all my Zip/Jaz drives brought over from Oz, nice timing 😀
Reply 11 of 14, by idspispopd
386SX is certainly the slowest CPU that can run 386 enhanced mode, but Windows 3.0 can also be used in standard or real mode enabling it to work on an 80286 or 8088/8086.
Also, you should be able to run Windows 3.x from a Zip floppy.
Reply 12 of 14, by computergeek92
Just picked up my 386SX 16 tower today! 😁 Has 3.2megs of ram and a 125mb hard drive. I can't wait to test this baby out sometime! Here's what it looks like:
http://thumbs1.ebaystatic.com/d/l225/m/mCUKxl … lxCHbqJJBSw.jpg
Reply 13 of 14, by yawetaG
IIRC, there was a tool suite for both DOS and Windows (Iomega Tools?) included when we bought our first ZIP-drive back in the 1990s, that had very little differences between the Windows and MS-DOS version (beyond the user interface). Don't know whether the Windows version works on Windows 3.0, but you didn't need it to use the ZIP drive - you do need the DOS driver.
Windows 3.x didn't include any drivers for technology that was not yet developed when it was in development...
Reply 14 of 14, by Jorpho
Toobox for Zip, yes. Looks like Archive.org has it:
https://archive.org/details/Iomega_Toolbox_fo … Jaz_Iomega_1997
