First post, by feipoa
- l33t++
Has anyone had success running the ET4000/W32i (or ET4000AX) in Win3.11 at 1024x768 at 256+ colour on any 386-based motherboard?
I have tried 6 different 386 motherboards, using the Cyrix 486DLC or Ti486SXL. At 256+ colour, I get unsupported mode. At 1024x768x16colour, I get a flickering screen. 800x600x65000colour works fine. Is there a limitation of how many colours/pixels the 16-bit ISA bus can display? Is it a motherboard limitation? Is a specific driver required?
I have added the 2nd 1 MB of RAM, via DIP sockets, to my ET4000/W32i card, for a total of 2 MB. Could the issue have something to do with the soldered video memory being at 45 ns, while the added DIP memory is at 70 ns?
What max resolution/colour should the ET4000/W32i support with 1 MB and with 2 MB? What about the ET4000AX with 1 MB and the ATI Mach64 with 2 MB?
Is there something I need to set on the monitor? The test monitor is a 1280x1024 native resolution LCD. LG 782LE.
