First post, by chrisNova777
is there a trick to get this to work? i thought the header was on backwards ive tried putting it on in any orientation that it will work..
is there like bios settings or something? how come i cant get the ps/2 mouse to work on my Asus (VL/i-486Sv2gx4) 486 mobo..
mouse never works!!
Reply 2 of 101, by chrisNova777
the only place i see ps2 mouse is in irq 12 settings under power mgmt
im using a roll ball ps2 mouse by labtec .. it says 3b mouse on the bottom
Reply 3 of 101, by firage
There's a PS/2 mouse enable/disable jumper "JP7" above the top VLB slot and by the keyboard controller near the front, bottom pins of a three jumper block. 1-2 enable, 2-3 disable.
My big-red-switch 486
Reply 4 of 101, by tayyare
During that times, there was no PS/2 motherboard pinout standards, so many motherboard manufacturers were supplying their own unique PS/2 back plates. You need to check that back plate plug and motherboard connector has compatible/same pinouts.
Just to give you some idea:
Unfortunately, the only manual I can find for your mobo, shows no details about the PS/2 mouse connector, other than that it is a PS/2 mouse connector. I have two motherboards with PS/2 connectors on back plates, and in both cases, I need to change the back plate connector and re arrange the cable leads according to mobo manuals. These guys might be an easy place to obtain suitable connectors:
http://www.frontx.com/order_c.html
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 5 of 101, by chrisNova777
ok i checked my jp7 settings.. theres a cluster of 3 jumpers there.. the top + bottom ones are set to 1+2 and hte middle one is set to pins 2+3 (the manual says not to change it) so according to the manual the ps2 mouse is enabled.. at least according to the jumper setting.. next to it - it says irq12.. maybe i have something stealing irq12?
to tayyare:
the ps/2 header on my motherboard isnt in a single line like that.. its a 2x5 configuration
heres a pic (not of the exact board i have, but a similar board with similar 2x5 ps2 header)
file.php?id=19295&mode=view
im booting win98 off a cf card and everytime its "windows did not detect a mouse attached to the computer.
id really like to start using this 486.. this is the only obstacle in the way of me enjoying And setting this computer up with a new os + programs installed
Reply 6 of 101, by chrisNova777
is there anyone else with this exact board?
that has a ps/2 mouse working?
do i need to do a bios update?
Award modular bios v4.50G, an energy star ally Copyright (C) 1984-95, Award Software, Inc. #401A0-0401 80486DX2 CPU @ 66Mhz Memo […]
#401A0-0401
Memory Test : 32768K OK
08/22/95-SIS-85C471-I486SV2G-00
Reply 7 of 101, by alexanrs
Before suspecting software issues you need to be sure your PS/2's backplate connector matches the pinout of the header on your motherboard. Since this motherboard came with the header soldered on, I REALLY doubt it came with a BIOS that doesn't support it.
Reply 8 of 101, by firage
I have the pinout and I can confirm it works:
8.3 KiB
The picture is from Vogons a while back, credit to the user emote in this thead: PVI-486SP3 Documentation / Manual
Reply 9 of 101, by chrisNova777
wow im an idiot.. ok the pinout of the adapter i have is 2x5...
the actual pin of the header.. as shown by your document u just posted is actualyl 2x4!!!!!!
i bought the wrong stupid ps/2 header.. Model: PLATE6F from startech.com http://www.startech.com/ca/Cables/Serial-Para … Bracket~PLATE6F .. wrong one for this motherboard;(
does anyone know how i could change the pins inside the header connector? because it will obv fit on with 2 pins hanging off to the side. if i could only rearrange the pins in the connector.. but i dont know how this thing works.. do i need a special kind of tool to eject the pin connector/wire into the black pin header?
i cant believe this is the reason.. 🤣 i feel so stupid.
ive already waited for weeks to get this stupid thing
Reply 10 of 101, by firage
You can usually mod those connectors if they're approximately the right pitch, by carefully extracting the wires and moving them around. The one I currently use is a 1x6 that I've cut up good. 🤣
Reply 11 of 101, by chrisNova777
im not so good with things like that ill just end up braeking it
unless theres a way to just pop out the pin connections and relocate them and snap them back in
looks like i bought the wrong type
anyone know a good company i can order the right part from?
https://www.computercablestore.com/pc-insert- … board-connector
https://www.pccables.com/products/06010.html
http://www.connectworld.net/cgi-bin/rrdata/L1225
Reply 12 of 101, by firage
They wires come out cleanly, just need to lift the tiny lip with a small screwdriver, the tip of an exacto knife or something. The careful part is in not breaking the lip on any pins you still need to hold a wire in later.
Reply 13 of 101, by alexanrs
You can use a very small screwdriver to lift the plastic tabs near the end of the connector and, with the tab lifted, pull the connector. I've done it more than once, with no special tools, you just need a somewhat steady hand and patience.
Reply 14 of 101, by chrisNova777
ok i found this previous vogons post: PS/2 Bracket for Asus Motherboard Header
and following the instruction i used a screwdrivr to pullback the plastic tabs to be able to remove the wire/pins from the sockets and re-arrange them
but unfortunaetly i must have made a mistake because im still getting the no ps2 mouse screen 🙁
from top to bottom,
left to right
i arranged the pins like so:
yellow | x
x | x
brown | x
red | green
Reply 16 of 101, by chrisNova777
alexanrs wrote:
Try using a multimeter and check continuity to see if you are getting it right.
unfortunaetly i dont have one
im now trying this config:
yellow | x
x | x
red | x
brown | green
.. another fail
Reply 19 of 101, by chrisNova777
yea well nothing is working.. maybe i should try changing the jp7 jumper even tho from what i can tell it looks to be enabled already
the yellow wire is the voltage right? pretty sure i have that in the right location on pin 4 (top left)
question is.. which color is ground? data? click?
like i said i have yellow + red,green,brown wires
    105.75 KiB
