First post, by sirlemonhead
Hi,
I've a few Mitsumi drives here that aren't working - giving the 'drive not ready, abort retry fail' error on DIr in DOS. The laser passing across the disk repeatedly so it looks like it's unable to track(?)
What's the best and safest method to clean the lens on the drives? The one I have open now has a slightly murky looking lens - these drives have been in an attic for a few years!
I have some 70% isopropyl wipes here, and some q-tips but I don't know if these are cotton or not? I don't want to scratch the lens...
Thanks!
Reply 1 of 5, by Imperious
Q-tip (cotton buds) and Methylated spirits also works, just use the dry end afterwards.
PC's from XT 8088, 486, Pentium MMX, K6, Athlon, P3, P4, 775, to current Ryzen 2600.
Reply 2 of 5, by PCBONEZ
I use 91% isopropyl from a spray bottle. (Less water content. Evaporates fast.)
I usually just use the force of the spray and nothing mechanical.
Also works good to clean PC Boards.
Reply 3 of 5, by sirlemonhead
Thanks guys, I'll see what I can find at the weekend - might be a bit tricky to get hold of more isopropyl here. I'll try the chemists 😀
I quite like that idea of the spray bottle..
Reply 4 of 5, by konc
You can ask for it in pharmacies. It commonly known as "rubbing alcohol" and I believe in UK/Ireland as "surgical spirit". Of course these guys should also know it as isopropyl alcohol or isopropanol. Just make sure it's isopropyl, (sometimes it can be ethanol!) and not scented or anything 🤣
Reply 5 of 5, by PCBONEZ
Yes, "rubbing alcohol" or whatever it's called locally.
It comes in various strengths with the percent shown being how much is alcohol. The rest is water.
I've seen it everywhere from 50% to 99%. The 70% is most common in the US with 91% being the second most common.
The higher the % of alcohol the better it cleans and the faster it evaporates.
While the 70% will get the job done the 91% works noticeably better.
The 91% should not need any help drying out where the 70% may or may not depending on how humid it is where you live.
So long as you've flushed the area completely Isopropyl leaves behind no residue.
If you see a residue it is something the Isopropyl loosened up that didn't get flushed out.
If cleaning something large (like a whole motherboard) it's a good idea to use it outside or have a window open or do it in the bathroom with the exhaust fan going,
Denatured alcohol (ethanol based) is not the same thing and is not recommended for electronics work. (Least not by knowledgeable techs.)
It has other additives which are not standardized (different brands use different additives) and those additives may or may not leave a residue.
The residue may be oily, conductive or corrosive to electronics depending on what that company uses.
Smaller stores/pharmacies may only stock 70% where bigger stores usually have both 70% and 91%.
In the US if you are having trouble finding 91% - Walmart and some Sam's Clubs carry it. (And it's cheap there.)
Probably many other places I don't frequent as well.
