First post, by MrMateczko
- Member
1. All Nvidia/S3/SiS Win9x graphic drivers have this string EMMExclude=C000-CFFF put in the 386enh section in System.ini during installation.
But, the latest ATI Catalyst 6.2 does not have this string included.
I've looked at Google too see what it does, and some says it makes the boot slower, is needed for a secondary display, and might cause problems with EMM386.exe.
Can someone explain me if is it needed for normal operation without a secondary display.
Will removing this remove my boot delay I have with my MX 440? It takes an additional second to boot to GUI after I install the driver. WIll it make the games run faster? (probably not :p)
2. My motherboard is an ASRock K8Upgrade-NF3, with the latest BIOS P2.40.
There's a few seconds delay after the POST screen, and before any booting starts. The cursor just blinks during that time. It takes about 4 seconds.
It happens regardless if I boot from my IDE HDD, or my USB Flash Drive. (I forgot if it happens without any boot devices)
I've tried all the BIOS options, but nothing fixed the issue.
Will downgrading the BIOS fix the problem?
