First post, by SquallStrife
Everything I've found via Google on the topic has been high-level and abstract.
I want to know, if you probe a low signal (<0.8v) on A0...A19, is that a 1 or a 0? I know I can find out myself, but I'm sure someone here will know off the top of their head!!
[retro swim] | Link | Release Thread
Regular silliness on Twitch!! http://www.twitch.tv/RetroSwim (8PM Mon, Wed, Sat AEST)
Reply 1 of 5, by alexanrs
AFAIK a bunch of TTL logic is used on many expansion boards, and Sergei's turbo XT SBC uses 74LS (or 74HCT) glue logic for just about everything.
For TTL 0-0.8V is low, 2.2-5V is high. Everything in between is undefined.
Reply 2 of 5, by SquallStrife
I get that.
But would, say, low-low-low-low represent 0x0 (thus "active high") or 0xF ("active low")?
Reply 3 of 5, by alexanrs
AFAIK for the address lines exposed on the ISA slots are active high. A quick look at Sergei's schematics seems to confim that (ROM chip being enabled when A16-A19 are high)
Reply 5 of 5, by tyuper
Only control lines (e.g. IO port read/write or memory read/write) are active low signals. Everything other is active high. On the web there is good book about x86 architecture and ISA bus https://archive.org/details/ISA_System_Architecture
