First post, by jesolo
- Oldbie
I know that there has been quite an number of discussions around the various Cyrix made chips.
So, instead of opening up old threads, I'd thought to just ask a couple of questions, after which users can just point me to an old thread for an answer or just reply on this thread.
Cyrix 486DLC CPU's & their derivatives
I know that Texas Instruments also produced CPU's with their logo on it, based on the Cyrix 486DLC.
What confuses me a bit is that there seemed to be two naming conventions, namely the TI486DLC and TX486DLC chips.
For example, I came across examples of two Texas Instruments 486DLC based CPU's, namely the TI486DLC-E-40BGA & TX486DLC-E-40GA
What's the differences, if any, between these two?
Did both employ 1KB of L1 cache (like the Cyrix CPU's) or, did they employ 8KB of L1 cache?
I know that the later TI486SXL-40 CPU did employ 8KB of L1 cache (also had some clock doubling features, but disabled by default - based on some posts I read).
Cyrix 5x86 CPU's & their derivatives
I know that SGS-Thomson also made a CPU, based on the Cyrix part, namely the ST5x86V10HS.
Anything particularly special about this CPU, compared to the standard Cyrix 5x86-100GP CPU (I kind of like the one with the green heatsink)?
Would the ST based CPU be a later revision of the Cyrix made CPU? How well does it overclock?
