First post, by Megadisk
Today I was taking my 80286 IBM/Sega Teradrive for a spin after adding some new ram simm sticks into it (the cover was off for testing purposes) when I accidentally touched the N80L286/10S CPU and notice it was running scorching hot to the touch only after about a minute of two of gameplay. My question is, is it normal for those old CPU's to run that hot?
Thanks in advance for any replies.
Reply 1 of 4, by Trank
Even CPUs of today run above 100 degrees easily. Even 40 celsius is above 100 degrees. Which to human skin would hurt a lot. So yeah, that is quite normal, CPUs are hot when they get used. If i were to touch my Pentium 3 after playing 1 minute of Quake it would be hot.
Put simply, yeah its ok.
Reply 2 of 4, by Megadisk
If that's the case then no biggie. Thanks for your reply!. After all these years this is the first time that has happened to me. Follow up question, so I guess these old CPU's weren't engineered/designed (or had in mind) to have heatsinks?
Reply 3 of 4, by nforce4max
Back then people didn't care if these got hot so long they were stable, personally I would just slap a stick on heatsink and forget.
