PCBONEZ wrote:Scali wrote:PCBONEZ wrote:Yes sound cards have amps but they aren't necessarily powerful enough to drive unpowered speakers.
I would say they are.
Yes, the ones we're talking about here, yes (the part you failed to quote)...
If an output can:
a) Drive headphones
b) Be used as line-out
Then the conclusion is:
a) It can handle devices with low-impedance such as headphones/speakers
b) It can produce a signal to a certain nominal level
Combine a) and b) and you pretty much can't go wrong powering some speakers.
So yes, any sound card with a multi-purpose output (which is all early Adlibs and Sound Blasters, most clones, and probably 99% of all consumer soundcards/onboard in use today) will drive speakers.
There will be exceptions, but they will be rare.
Given that this topic is about 386-era soundcards, chances of it not working are pretty much 0. Unpowered speakers were a very common use-case in those days, and in fact, various 'multimedia kits' were even sold like that (sound card bundled with speakers, microphone, CD-ROM drive, some software, sometimes also a MIDI kit).
