First post, by vlbnn
Greetings to all.
In autumn '99 I bought my first Aureal card (before was SB16 Vibra and after SBLive! 5.1) - MX300 and it was great time (Half-Life, Heretic, Unreal and SBLive! holy wars)). I own this card and these days and I always wonder about its awesome technologies. I already read a big list of various explanations about A3D but almost all of them is basically parts of Aureal marketing materials. Here I found some useful technical information and want to ask my other questions:
1) what parts the "A3D engine" (on Au8830 scheme) consist of? To my opinion it includes: HRTF filters and atmospheric filters. Anything else?
2) if I correctly understood explanation about famous wavetracing technology it relies on the CPU (via A3D API and drivers) in matter of bouncing rays and computing second emitters of sound (i.e. dots from which reflections is propagating), delays, amplitude, coordinates and transmit these parameters to Au8830. Is it true? What part of job doing Vortex 2 then? Applying HRTF to refletions and mixing them? Or something else? To me (at this point) the biggest hardware advantage Au8830 vs. EMU10K1 is support of huge hardware channels (76 vs. 32) which cannod be emulated in any way even though geometry calculation can be done in software.
3) support of only 16 A3D sources - is it hardware or software (i.e. drivers) limitation? What is the difference between these 16 and other 60 (the last is the midi channels, right?)? I've read somewhere that it is hardware limitation and Au8830 does not apply HRTF on the 60 reflections channels but it is unproved...
4) EMU10K1 includes DSP (FX8010) which capable of executing microcode written by user (i.e. Creative programmers in most cases). There are some little memory inside which limit the complexity of algorithms DSP can execute. My question is as follows - Vortex 2 works in the same way or it cannot be programmed for various tasks using its own commands? Someone told me that the latest drivers (or cannot Aureal doesn't implemented it and it was his wishes) for Vortex 2 can download HRTF to it and program its chip in some way.
5) about reverb - does Vortex 2 support it in hardware? And if it so what kind of reverb? I read here that latest revision B0 maybe does.
6) about games (with wavetracing) - to me the best A3D 2.0 support is in Unreal/UT and Heretic 2. I tried famous Half-Life many times and it not that cool to me. I try to explain it more clearly: in both Unreals the reflections help me almost feel things around me, but in Half-Life reflections come from all directions with identical force. I always tried all games with headphones only. In Half-Life s_geometry and s_reflect both set to "1" and drivers play Aureal sound at level startup. Even Quake 3 is better in this case - turning A3D gives shotgun fires be audible according to around geometry. Anyone else have this experince with Half-Life?
There are other questions (I think they will be interesting for people here) but for the first time these six are enough.
Reply 2 of 3, by firage
If you want more suggestions for games, Descent 3 is one of the best showcases for A3D 2.0. It adds a lot to the experience.
My big-red-switch 486
Reply 3 of 3, by vlbnn
ZanQuance wrote:
Be sure to check out my reverse engineering thread I started here
Thank you, I already read this thread. And I have another question based on it: you write there "Everything that Daughterboard was originally designed to do has now been done in software, Dolby encoding/decoding, EAX reverb, more 3D sound sources..." and answer me with "Reverb is done in hardware in the WT cell...". It is mutually exclusive.)
ZanQuance wrote:
What I've found is that there are actually a total of 192 mono audio channels.
I.e. Aureal can easily increase voice count by driver update? But 16 A3D Sources cannot be altered in any way, right? If it so then they can be new reflection channels, I think. By the way Creative operates "ghost" 131 channels for EMU10k1 in their press-releases...) -> http://support.creative.com/kb/ShowArticle.aspx?sid=5805 ("Capable of processing, mixing and positioning audio streams using up to 131 available hardware channels"). But maximum that I can get of SBLive! card is 64 DS and 32DS3D channels at all (with VXD drivers)...
ZanQuance wrote:
Creative lied so much
Agree.
ZanQuance wrote:
Vortex audio Data Bus VDB
I found it interesting that some people think that EMU20kx is in some way Vortex 3 with its ring architecture (like Au8830 has). What do you think about it? Is it right that EMU20kx has inside many ideas they took from Au8830?
ZanQuance wrote:
Each channel can have 4 effects applied at once in hardware
Can you write example of these effects please? This is something like Creative effects (reverb, chorus, flanger) or something else?
ZanQuance wrote:
Reverb/Delay WaveTracing, HRTF and panning, and Gain
Can you please explain me what do you mean here by panning and gain? Is it that panning Aureal used for rear speakers or not?
ZanQuance wrote:
ITD params
What is that?
ZanQuance wrote:
It has the full programmable HRTF filters
Oh, this is the thing I read as "downloadable HRTF".) I.e. it may be updated if necessary... Very well, a good answer to EMU10kx programmable DSP.
By the way: i cannot see at scheme path in back direction from A3D engine and Crosstalk canceller? Is it mistake or not?
ZanQuance wrote:
There is only a 16 channel limit passing data through the A3D channels at a time
In the 98-99 it was been enough but later I think (in Vortex 3) they upgraded it to 32-64 voices.) But (Creative)...
ZanQuance wrote:
It's a hybrid system of sorts, for a modern implementation it's better to have the GPU do all the work and pass the final parameters to the soundcard for mixing.
Agree.
Can you in simple terms explain me next thing: for example in Unreal (as well in H-L, Heretic, Sin, ...) there is such console parameter - s_maxreflectpoly which is set by default to 100 and I usually increase it to 500-1000. But - in any way it is larger then number of reflection (i.e. wavetable) channels - 64(or even 60). How their algorithm choose polygons (only 64 from 100-1000(!)) which can be used to build reflectons? Or they do some interpolation?
ZanQuance wrote:
This means that the Audigy2 ZS only had 430 mips of power
Correct, its DSP has power about 100 MIPS (Live! has 50 MIPS -> !!! and all chip around 300+- MIPS).
ZanQuance wrote:
The AU8830 we assume runs at 50mhz
EMU10k1 for comparison runs at 100MHz and EMU10k2 at 200MHz but their results far from perfect...
ZanQuance wrote:
It was also stated to have an internal bus bandwidth of 900MB/s.
Such a huge bandwidth for '98...
ZanQuance wrote:
With rev B0 of the chip I think they only adjusted the internal silicon to make it 12% faster.
Maybe they increase bandwith of VDB or in such a case it breaks all internal timings?
ZanQuance wrote:
At all times you should only be using the 2041 drivers with Half-Life, they were the best set of drivers and work really well all in all.
Already use them, thanks.
Thank you, I'll give it a try when buy joystick.)
