First post, by Jim Cox
I have the American Megatrends 80486 Enterprise-IV EISA motherboard but no American Megatrends EISA config utility for that board, 2 files are needed-!AMI87A1.CFG and AMI87A1.OVL). anyone help out with those files?
Jim Cox
Reply 1 of 4, by Anonymous Coward
There is a very high chance they are still on the ami ftp server.\
User Manual: http://www.manualslib.com/manual/208704/Ameri … erprise-Iv.html
*edit* found the CFG. Just need the OVL
http://tomas.dscloud.me/eisa/!AMI87A1.CFG
Reply 3 of 4, by Anonymous Coward
I am pretty sure somebody around here has the enterprise IV.
ftp://78.46.141.148/mirrors/ftp.mdscene.net/f … /systemutil.htm
This page has a zipfile called AMIECU4. It is likely the OVL is contained inside it. Unfortunately the link is broken!
Reply 4 of 4, by 386_junkie
If this is the same board, I remember seeing it on eBay not that long ago.
It aroused my interest of course as I was wondering if, with a correct CPU processor board, it supported the utilization of a 386. It had a proprietary slot for the 486 CPU board but not sure if there is a 386 board with the same hardware configuration.
Was a nice board in any case. I hope you get the configurations loaded ok and the board working.
Would be good to see some pictures when you've time.
