First post, by Preluder
Hi guys, first off I've appreciate all the forum postings here, which I've found very useful in putting together an old PC to bring back some good old times.
Turns out that I've got everything set up, but for some reason my processor speed is waaaay to slow, and I can't figure out why.
It's running on a PCChips board with the UMC chipset, got all the jumpers set up properly according to the manual and processor specs, changed some bios settings but nothing changed, if anything I've managed to get an even LOWER score in speedsys. 3DBench results in 11.1 fps, thats BS!
What could be wrong with this? any help will be much appreciated! 😊
Reply 1 of 19, by clueless1
Could cache be disabled somewhere...turbo button turned off?
Reply 2 of 19, by Sutekh94
I wonder if this could be one of the infamous fake cache PC Chips 486 boards... Maybe a pic of the board itself might help?
My YouTube | My DeviantArt
Reply 3 of 19, by Preluder
In the bios the "Internal Cache" is Enabled, other than that there are no more options.
The turbo button jumpers are bridged, so it's always on.
Heres' a pic of the board:
In mine the chipset says BA1915 instead of RC1047, but the rest looks the same.
Reply 4 of 19, by alexanrs
After the POST screen, but before the "Starting MS-DOS" message, PCs usually show a bunch of information. Does it say anything about the amount of cache installed?
Btw I'm pretty sure "Internal cache" means the processor's built in L1 cache. You could also try something like CACHECHK to check your cache.
Reply 5 of 19, by Tetrium
Preluder wrote:
In the bios the "Internal Cache" is Enabled, other than that there are no more options. The turbo button jumpers are bridged, so […]
I can't read the print on the PCB to check if the CPU (and the rest of the board) is jumpered correctly.
At first glance your cache chips seem like real ones, one of them seems socketed, which is a good sign (though of course no 100% guarantee)
And agreed with using a program like CACHECHK 😀
edit:
Wait, this isn't a pic of your actual board then?
My retro rigs (old topic)
Report spammers here!
Reply 6 of 19, by Preluder
Well here's a pic of my actual board, at least the part that can be seen. The rest is covered in wires and cards.
It says "256kb internal cache" at start, but cachechk said "this machine does not seem to have any cache"
And this is the mobo info and manual, all the jumpers set up according to this:
http://motherboards.mbarron.net/models/486vlb3/m912v17.htm
Reply 7 of 19, by Skyscraper
Perhaps the soldered cache is fake?
I would still try to remove the jumper bridging the turbo button header as a Speedsys CPU benchmark result of 10 is way too low for a DX4-100 even without L2 cache. On some boards "turbo on" is the "fast" setting and on other boards it's the "slow" setting.
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Reply 8 of 19, by tayyare
Maybe a trivial subject since you already checked that, but do you have any "startup speed" kind of option in your BIOS settings? There are boards from that era which has this option and when set to "low" starts as turbo button is in low speed status.
"256KB Internal Cache" is kind of weird (nothing has that much "internal" -L1- cache during that period of time, not even close) so looks like a bogus statement. Your board might be a fake cache/BIOS modded PCChips.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 9 of 19, by Sutekh94
Yeah, that board definitely reeks of PC Chips - the UMC stickers on the chipset tell all. Also the "WRITE BACK" labels on the cache chips are a pretty telling sign that they are fake.
http://redhill.net.au/b/b-bad.html
Reply 10 of 19, by Preluder
Well it actually says "256kb cache enabled" no matter what.
Just checked the link for the pc-crap boards, and well, looks like it's one of those... but the UMC chip is still an UMC chip! 😀
Let's see what's under these two:
Bingo, still an UMC chip? 😊
Not this one:
BIOS soldered to the board:
And fake cache?
Reply 11 of 19, by Skyscraper
Yes those cache chips are fake!
The board should still not be that slow in the Speedsys benchmark.
Reply 12 of 19, by johnnynismo
I'm confused. On earlier pictures it looks like you have socketed, 32-pin, 15ns SRAM with a 28-pin TAG. On these latest ones, it's soldered onto the board. Were the previous pics just examples you found? The soldered "write back" cache does seem pretty suspect TBH...
Reply 13 of 19, by Stiletto
Yes he did, here's the source: http://motherboards.mbarron.net/models/486vlb3/m912v17p.jpg
do the Fandango!" - Queen
Stiletto
Reply 14 of 19, by johnnynismo
You know....this really makes me appreciate tech journalism. If we had had PCPer, The Tech Report, Anandtech, and all the others like them manufacturers never would have been able to screw people over with FAKE CACHE! Duping the public is much harder to do nowadays.
Preluder, I hope you find another 486 mobo soon. I've run across a few appropriately priced ones on eBay so I'm sure you can find something. I even found a set of 32-pin SRAM with TAG to upgrade my Packard Bell Legend 125 from 128k to 256k just this morning so there's still hope. GOODLUCK!
(interesting side-note...I discovered the hard way that 128k of L2 cannot cache 36MB of RAM. I installed Windows 98SE on it and it fell on its face!)
Reply 16 of 19, by Mr_ppp
The picture comparison does look iffy in the second one, looks like the infamous black plastic with metal legs instead of real cache, no sockets anymore, no jumpers to the right of the cpu socket just soldered wire links unlike the previous image and several umc chips with sticky labels - makes me want to go check my own boards now as I have several pc chips models!
Reply 17 of 19, by Preluder
Well, I've got this thing real cheap anyway, came with Trident VGA card, a controller board, both floppy drives (none of them worked), all within the case, including a Cx486DX2-66 processor, all for less than $20.
I've added the EDO RAM (16mb), my old Sound Blaster AWE32, a better controller board, 6gb HDD and a 15" SVGA SyncMaster CRT monitor (stuff I've had kept from older PCs).
The Intel 486DX4-100 came afterwards, got it for $20 bucks.
Found this mobo, MV035 OPTi, it has all the features I'm looking for, including an AMD 486DX2-66 all for less than $50. Just need to add the battery and BIOS from the other board and should be good to go.
Reply 18 of 19, by kanecvr
Two things everyone seems to be ignoring:
1. cachecheck is reporting "this machine doesn't seem to have any cache" witch means the cpu's l1 cache is either turned off or not working, otherwise cachecheck wold say "this machine has one level of cache"
2. you seem to be running the cpu without a heatsink or fan. The 486 dx4 REQUIRES a heatsink at least.
Reply 19 of 19, by Preluder
Well it didn't really had time to heat up since I've been doing the tests and it's performance is at 1/3 of it's capacity. I've seen a lot of these without heatsink or fan, I have a couple of spares to use on it anyway.
Right now I'll see if that mobo I've found could turn out to be useful, not sure if the BIOS from the pc-chips board will work since it might be modified to run without cache.
