First post, by markot
I'm trying to put together a working keyboard by taking parts from two s****y keyboards. The other keyboard is not working at all, someone have put some glue or something in the keys. The other one seems better, but clips holding together the casing are broken. What would be the best way to fasten the casing when the clips are broken?
Reply 2 of 3, by adalbert
Hot glue? :p make sure it gets as hot as possible, put it in place of broken clips and assemble everything quickly (keep it squeezed together by putting a lot of force for couple of minutes). I did something like this with a laptop and it worked. You can warm it up with a hairdryer if you want to disassemble. It's not a cleanest solution, but it doesn't require modifying the case.
Repair videos: https://youtu.be/T6mXM1tA7pA
Reply 3 of 3, by markot
I decided I will try another approach. I will use epoxy glue and try to put the broken parts together very precisely one by one. The drying time is about 24 hours, so have to use adhesive tape to keep the parts intact.
