First post, by Triton
Hello, I am having an issue with my Pentium 3 gaming box that despite my best efforts have been unable to fix.
In just about every game that has FMV I am getting framelag in the playback - it looks like the video is running at half the framerate - although there is no problem with the sound. I am also getting surprisingly 'stuttery' framerates in many games that my computer should easily be able to handle (Half-Life for instance). Splinter Cell seems to run at half the framerate that it should too no mater what settings I apply. Here's the really confusing part: when I disable my sound device through Device Manager, it fixes video-everything! (although at the cost of sound, obviously),
Here are my specifications:
CPU: P3-S 1.4ghz
RAM: 512 MB SDRAM
GPU: GeForce 4 Ti 4400
Motherboard: Aopen MX3S (i815e chipset)
Sound: Sound Blaster Live! 5.1 (SB0220) / (I also tried enabling an integrated SoundMax on the motherboard but it made no difference)
PCI: VIA USB 2.0
Operating system: Windows 98 SE
I have tried pretty much everything, removing the two PCI cards and enabling integrated sound instead of my Sound Blaster Live! 5.1, changing different Nvidia drivers in case that was the problem (the year 2002 driver seem to work better than the later ones though...), disabling/enabling other drivers. I even swapped in a different CPU (Coppermine 1.0ghz) to see whether that was the problem, and I also ran Memtest86+ for a few cycles.
I would really appreciate if somebody could help me, I just can't understand how enabling sound could give such an enormous performance penalty even to video playback, especially when I have a card that is supposed to process sound in hardware.
Reply 2 of 14, by Triton
SRQ wrote:
Try installing the UESP 3.1 update pack, it made a world of difference on my high-spec 98 systems,
Hi SRQ. Thanks for the reply. By UESP do you mean the Unofficial Service Pack for Win98SE? If so, is there any particular reason you recommend version 3.1? I've noticed there are newer versions available, but I suppose they might be unstable.
Reply 4 of 14, by SRQ
Yes, and I had no idea there was a newer version! Go for it. I always instal the basic updates as well as the optimization package.
Reply 5 of 14, by Triton
Snayperskaya wrote:
You could probe your system's DPC latency with DPClat, but I'm not sure it runs on 9X.
Hi Snayperskaya, sadly DPClat doesn't seem to work under 9X, I'm getting a DLL error when I try to execute it. Maybe it'll work after I install the USP.
Reply 7 of 14, by Triton
SRQ wrote:
I should also note that it was pointed out to me that 41.09 drivers have the best compatibility. I have no source, but it's better than trying them all on your own.
That is exactly what I discovered during my attempts at diagnosis. It really is the fastest driver that I found (seems to be missing options to change the refresh rate though - that's pretty odd!!).
Reply 9 of 14, by SRQ
It's very annoying but if your monitor has an EDID or you have an INF for it you can do it through display settings.
Reply 10 of 14, by alexanrs
A few suggestions:
1- Be sure that DMA is activated for the HDDs and optical drives
2- Are you using the VxD or WDM drivers for tre Sound Blaster Live!? Try using the other.
3- Put the SBLive! in a different PCI slot. Try using one where it doesn't share an IRQ with anything.
Reply 11 of 14, by Skyscraper
I would try to remove the VIA USB 2.0 PCI controller card as a first step.
I would disable the secondary IDE channel if you are not using it and also disable every port you are not using. A clean install is also a good idera as by now your system probably is littered with different bloat that diddnt solve the issue.
If this dosnt fix the problem I would start looking at the PCI settings in the BIOS setup and check online for Win 9x PCI latency fixes for the i815 chipset + SB Live!.
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Reply 12 of 14, by Triton
I've got an update. I formatted Windows 98 SE and just installed graphic and sound drivers. The problem happened. Then I formatted the system and installed Windows XP and just installed graphic and sound drivers. The problem didn't happen. That suggests to me that the problem is either with how well Windows 98 SE plays with my hardware...or it's with the drivers.
Hey thanks for your suggestions.
I tried the removing the VIA USB 2.0 card, I even tried removing the Sound Blaster and just going integrated. I didn't try disabling the secondary IDE channel (it's just got a single DVD-RW), but it didn't look like there was a conflict.
alexanrs wrote:
A few suggestions: […]
A few suggestions:
Cheers Alexanrs
I made sure DMA was enabled for everything and also tried moving the PCI card.
From where I'm looking, I think your suggestion about changing the drivers between VxD and WDM might be on the money. I actually wasn't aware of this but the SB0220 driver disk comes with both VxD and WDM drivers. I'll have to try them both after I put Windows 98 SE back on and see what happens. I also found that the integrated sound comes with VxD and WDM drivers too.
Reply 14 of 14, by Tetrium
Triton wrote:
I've got an update. I formatted Windows 98 SE and just installed graphic and sound drivers. The problem happened. Then I formatt […]
A few suggestions:
Cheers Alexanrs
If you can (and I mean more like "if you have it laying around already"), you could opt to install Windows ME instead of 98SE.
Some members have reported running a Tualatin rig with ME resulted in fewer problems compared to running a Tualatin with 98SE. Not trying to say that ME is teh most obvious choice for such a rig btw, but you might as well give it a try as it probably won't take very long to setup (only need to install ME, tweak it a bit (disable that system health/restore thingy as it's a source of a lot of problems) then install drivers and see how it goes, you might actually end up liking it 😀
My retro rigs (old topic)
Report spammers here!
