First post, by Windows9566
I get only 200 or more conventional memory in dos mode, but in Windows 98, i get more conventional memory, in dos mode, some dos games like epic pinball say that i need at least 560K of memory.
my rig
Gateway LP Minitower TB3 Essential
Intel WS440BX ATX motherboard
Pentium III Katmai 500 mhz
256 MB SDRAM
nVidia Riva TNT2 M64 AGP 32mb
Creative Labs Sound Blaster 16 CT2830 ISA sound card
my config files
AUTOEXEC.BAT
SET BLASTER=A220 I5 D1 H5 P330 T6
SET SOUND=C:\SB16
C:\SB16\DIAGNOSE /S
C:\SB16\MIXERSET /P /Q
GoTo %config%
:EMS
: XMS
:CM
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:OPTICAL
LH C:\DOSDRV\CTMOUSE.EXE /R2
CONFIG.SYS
[COMMON]
DOS=HIGH,UMB,NOAUTO
FILES=30
BUFFERS=30
[menu]
menuitem=EMS, MS-DOS Mode with Expanded Memory
menuitem=XMS, MS-DOS Mode with Extended Memory
menuitem=CM, MS-DOS Mode with Conventional Memory
menudefault=EMS,30
[EMS]
DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\WINDOWS\EMM386.EXE RAM
DEVICEHIGH=C:\DOSDRV\VIDECDD.SYS /D:OPTICAL
[XMS]
[CM]
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
Reply 1 of 4, by keenmaster486
I've had great luck with QEMM (I use version 9). You run the install program and it automatically configures your system to have the maximum memory. And it will do the same thing for Windows if you have it.
I actually got ~740 KB on my 486 machine, even with all my drivers and stuff.
World's foremost 486 enjoyer.
Reply 2 of 4, by alexanrs
200KB is awfully low for the AUTOEXEC.BAT and CONFIG.SYS files you posted - you aren't even loading that many drivers?!
First of all - either remove the "NOAUTO" or use "FILESHIGH","BUFFERSHIGH","STACKSHIGH" and other directives to manually move those things to UMBs
Second - add the "/E" parameter to MSCDEX
Then, post the results of "MEM /C /P" and "MEM /F"
Reply 3 of 4, by chinny22
I use this site to base my startup files from
http://www.mdgx.com/mem7.htm
May need a bit of fine tuning for your system but at least your off to a good start and it explains what each line is doing
Reply 4 of 4, by idspispopd
Please post the output of "mem /c".
Also:
- I assume you refer to the [EMS] configuration? The others won't give you UMB's so the drivers won't get loaded high.
- If you don't need EMS you could add NOEMS to EMM386 for 64kb more UMBs.
