First post, by 386SX
Hi,
I would like to know which model of LCD possibly 4:3 for older video cards should I look for that have the same comparable crt colors/black/white levels? No excessive contrast/saturation, no excessive white or only blacks... the models you would not complain to switch from the crt considering in future I could eventually change my crt if will not last. 😀
Thank
Reply 1 of 9, by alexanrs
Such thing doesn't exist. Any LCD monitor WILL loose sharpness when displaying images outside their native resolutions. And 4:3 monitors are usually old, and much worse than current ones.
The next best thing would be a nice IPS panel that doesn't have a ver noticeable input lag.
Reply 2 of 9, by kanecvr
I can swear by these:
1. Iiyama Prolite B1906S: 19", TN pannel, LED backlit, 5 ms response time
Contrast: 1000 : 1 typical
Contrast: 20000 : 1 ACR
Brightness: 250 cd/m² typical
Brightness: 300 cd/m² max.
Viewing zone horizontal/vertical: 160°/ 160°; right/left: 80°/ 80°; up/down: 80°/ 80°
Viewing zone CR>5 horizontal/vertical 176°/ 170°; right/left: 88°/ 88°; up/down: 85°/ 85°
Display colour: 16.7 million
Pixel pitch: h x v 0.294 x 0.294 mm
Native resolution: 1280 x 1024 ( 1.3 megapixel)
Horizontal sync: 24 - 80 KHz
Vertical sync: 55 - 75 Hz
Synchronization: Separate Sync
Aspect ratio: 5 : 4
Inputs: VGA, DVI
Height adjustable stand: Yes
Height adjustment: 110 mm
Rotation (pivot function): 90°
Swivel Stand - 340°; 170° left; 170° right
Tilt angle: 20° up; ° down
VESA mounting: 100 mm
Available colours: Black, White
It does most non-vesa resolutions used by old dos games too. There's also:
2. EIZO FlexScan S2133
21.3-inch screen with 1600 x 1200 native resolution (4:3 aspect ratio).
IPS (in-plane switching) LCD panel (LED backlit) with 178° viewing angle.
420 cd/m2 brightness.
A stand with 82 mm height adjustment, 40° tilt, 70° swivel, and portrait mode viewing.
DisplayPort, DVI-D 24 pin, and D-Sub mini 15 pin inputs.
USB hub with one upstream and two downstream ports.
6 ms gray-to-gray response time for smooth display of video.
3. EIZO FlexScan S1923 and FlexScan S1903
19-inch screen with 1280 x 1024 native resolution (5:4 aspect ratio).
250 cd/m2 brightness.
EyeCare mode that lowers brightness to 3 cd/m2 to help reduce eye fatigue in dimly-lit offices.
A Stand with 100 mm height adjustment, 30° tilt, 70° swivel, and portrait mode viewing is available for both models. A basic stand with 30° tilt is also available for the FlexScan S1903.
Dual 0.5 watt internal speakers and a headphone jack.
Compatibility with older graphics boards that output a sync-on-green signal.
VA (vertical alignment) LCD panel (LED backlit) with 178° viewing angle for the FlexScan S1923.
TN (twisted neumatic) LCD panel (LED backlit) with 170°/160° viewing angle for the FlexScan S1903.
Reply 3 of 9, by 386SX
kanecvr wrote:
I can swear by these: […]
Aspect ratio: 5 : 4
Inputs: VGA, DVI
Thank for the models, I look for some review. 😉
Reply 4 of 9, by 386SX
Sure lower resoution will be upscaled and this is really a thing I can't stand it, but mostly I would prefer crt for the better gamma of colors, white and blacks that crt ever had and many lcd seems to have not yet.. lately I am using a cheap 17" crt and I'd find it superior to anything I daily see in both colors and definition even at 1024x768 with the dot pitch story.
Reply 5 of 9, by kanecvr
Back in the day, everything you said would have been 100% true - but today we have low response time led-backlit IPS LCD panels which offer better color reproduction then most CRT monitors I've used, great blacks and are sharper image then most CRTs - and I've used some high-end stuff back in the day. The days of the "washed out" and blurry LCD panel are long over.
The models I listed above are current-day 5:4 aspect ratio and have every enhancement brought to LCD monitors to this day (especially the IPS Eizo). They are designed for use in graphics and 3d modelling and as such have excellent color reproduction and great blacks. They do have a downside - they are EXPENSIVE.
I do have to warn you OP, I'm rather biased towards LCD monitors, mainly because CRTs give me headaches when spending more then 60 minutes in front of one. Even at 100Hz I can see the image flicker as my eyes get tired. Sure, when I was a kid I didn't mind CRT monitors because my eyes were a lot healthyer - but in my late teens sitting in front of the computer became very tiresome. It was then I saw my first LCD monitor and spend some time in front of it that I realized I need one. Colors were washed out, games were a bit blurrier, but the image was very sharp and my eyes didn't hurt even after four hours of gaming.
Reply 6 of 9, by 386SX
I can imagine having myself experienced the low vertical frequency cheapest crt monitor of the early 90's. I had one 14" that was incredibly good on color but needed 56Hz at 800x600... man.. 😁
Maybe I usually see the classic commercially sold lcd that have nothing but incredibly high numbers (ex 10.000.000:1 contrast oh yeah) but when in front of it you see only the usual very high dot pitch, useless ultra wide screen absurd resolutions, maybe deep black but not a gamma of greys or whites.... plus you could usually count the pixels at its native resolution.
I think I will look for the Eizo screen above and see what I can find. What about the dot pitch size? Are they good? I've seen that there are some with 0,23mm or better?
Reply 7 of 9, by zerker
I have a Dell 2001FP that I've owned for about 10 years which I'm using for my Retro PC. It runs at 1600 x 1200, is IPS and I couldn't be happier. It has a 16 ms response time, which isn't as fast as some models, but it's doesn't exceed one frame at 60 Hz (16.667 ms) and I never notice an issue with it.
Reply 8 of 9, by gdjacobs
The 2001FP was famous for blowing it's TICON board IIRC. The 2007FP is supposed to be better. Also the LP2065 by HP is supposed to be good.
Reply 9 of 9, by TeddyTheBear
http://tftcentral.co.uk/ has done some very in-depth tests of some of the current high end (expensive) LCD monitors. The interesting monitors to me are the ones with a blur reduction mode with a strobing backlight so the screen is only lit after the pixels have fully transitioned to the new color. This is very similar to the low persistence display of a CRT but of course as kanecvr mentioned this may give you eye strain if the flicker at lower refresh rates bothers you.
