First post, by TheAbandonwareGuy
Ok so i have a slight problem with my Retro machine. It won't boot. It's a Digital Celebris XL 590 with:
Twin Socket 7 90MHZ Pentiums
48MB of RAM across 4 slots
TRIDENT TVGA 3900D ISA Video Card 1MB
NVIDIA GeForce2MX PCI 32MB (No thats not its boot GPU)
2x Broadband Adapters
SoundBlaster 16 ISA
2GB HDD
Quad Speed SoundBlasterCD CD Drive
Basically i sat it down kind of hard one day and ever since its given beep code 1-3-4-1, Check 512k Base Address Lines
Im not really sure what the base memory is or how to test the base address lines. Couldnt find anything in the Digital Coporation repair manual.
Ive checked every connection and junction. The only thing i can think of is the RAM looking thing on the CPU board wiggles side to side a bit but is all the way in the slot.
How do i go about trying to fix this? i really dont want to have to pay 280 dollars to get a new retro PC off ebay (i paid 15 for this one, had been sitting in a garage for 20 years, worked when i got it though)
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 1 of 2, by gg1978
That error implies that it's having trouble addressing system memory.. Probably either bad SIMM's or the mainboard chipset is failing.. You might try reseating the CPU card.
Reply 2 of 2, by TheAbandonwareGuy
OK beep code error is gone (swapped out the DIMM on the CPU board with another identical one). New issue: Both CPUs are heating up, no video output. This is quickly turning into a nightmare.
