Schneider Euro PC
Reply 180 of 220, by dr.zeissler
I am thinking about MDA, CGA(RGB), CGA (COMPOSIT) on my EURO-PC. Is it possible to get composit out of the gfx-chip?
Reply 181 of 220, by Jinxter
dr.zeissler wrote on 2022-05-29, 13:10:
tereg posted this video in this very thread some time ago: https://www.youtube.com/watch?v=p-E7Qh1hnuM
Check out my YouTube channel: Retro Erik https://www.youtube.com/c/RetroErik
My collection: https://retro.hageseter.com
X: https://x.com/Retro_Erik
Reply 182 of 220, by Kekkula
Is there a way to boot straight from isa slot vga card. I don't have cga monitor but I have Trident tvga8900c isa card.
Also I can't find English manual for the machine does anyone have a link to manual?
Reply 183 of 220, by RetroBard
I gather if you disable the internal GPU from the BIOS, it should boot from an external GPU.
Reply 184 of 220, by Kekkula
There is no key shortcut to boot from external?
I can't get to bios since I don't have cga monitor 😁
Reply 185 of 220, by Jinxter
Kekkula wrote on 2023-05-10, 17:28:
If you study this video of the bios, you can do it blind. https://www.youtube.com/watch?v=qgv-CWJFU2s
Reply 186 of 220, by Kekkula
Thanks.
Found this site
https://oldcrap.org/2018/03/11/schneider-euro-pc/
It says push four times down then pgdn and enter
Does the machine boot without battery. I had corroted battery on board so I removed it and cleaned area. No traces seems to be damaged, but there are many beep codes when powering on the machine.
Machine seems to go to bios after pressing ctrl alt esc and when I press enter machine seems to reboot. But since i can't get any output it hard to know what is happening 😉
Edit: Problem might be as simple as the machine doesn't have a battery so bios settings doesn't get saved. So next step will be replacing battery.
Also wondering, I have amiga rgb to hdmi board, would it be possible to get it to work with xt machine?
Reply 187 of 220, by mkarcher
Kekkula wrote on 2023-05-10, 18:12:
The Amiga uses analog RGB (like VGA). CGA, EGA and Hercules use digital RGB. If you can't reconfigure your RGB to HDMI converter, you will get 8 colors at max from a video card with analog output, if it works sensibly at all.
Reply 188 of 220, by konc
Thanks. Found this site https://oldcrap.org/2018/03/11/schneider-euro-pc/ It says push four times down then pgdn and enter Does […]
Thanks.
Found this site
Yes the machine will boot without battery and will retain the settings while powered on and through resets. But it will complain and beep for all wrong settings until they are corrected.
Keep in mind though that depending on the damage done from the battery you might not be able to save the BIOS options until broken connections have been repaired.
Reply 189 of 220, by Kekkula
I just can't find the right compo to get the external video signal out. Might be the video card I'm using. It works fine with my hyundai xt clone, but I couldn't get it to show picture from my ibm 486 machine. So I'm thinking it might have some issue if there is integrated video chip on board.
So I'm considering options how to get video out from the original jack. Since I don't have cga monitor I'll have to use some converters.
https://www.serdashop.com/CGA2SCART-PRO
This could be the easiest solution, but I don't know if my flat tv supports scart rgb mode.
https://github.com/c0pperdragon/Amiga-Digital … /direct_adapter
I already have this amiga adapter but I don't think I can reroute signals from it.
https://github.com/hoglet67/RGBtoHDMI
This would probably be the best option, but I don't know witch version should I get 😁
Reply 190 of 220, by Scali
Kekkula wrote on 2023-05-17, 10:52:
The trick is to configure the onboard video card as monochrome (if it can't be disabled), then you can add an external colour adapter.
Reply 191 of 220, by konc
Scali wrote on 2023-05-17, 11:18:
I believe it can, the values for internal video are mono/color/disabled. Other models (can't remember if it's EuroPCII, EuroXT or both) had a "special" option for the external adapter.
Reply 192 of 220, by Jinxter
I came over this ISA Bus Extender for the EuroPC.
Made a short video about it to. https://youtu.be/fnERWxNNKPc
Our plan is to make a Universal ISA BUS Extender.
Reply 193 of 220, by RetroBard
Jinxter wrote on 2023-10-23, 16:17:
Nice! I should get one of those for my EuroPC. Is it available somewhere?
Reply 194 of 220, by matze79
https://www.forum64.de/index.php?thread/50459 … c-m3002-ersatz/
The attachment rtc3002.png is no longer available
Ivr from Forum64.de has made a Clock Replacement, if you looking for Parts to Repair it.
Reply 195 of 220, by microtronichamburg
RetroBard wrote on 2023-10-23, 17:10:
Yes, solutions are available - I made the following video about a year ago:
https://youtu.be/TPmV74Tdfdg
Also a list:
https://www.youtube.com/playlist?list=PLvdXKc … B0nTwQhQRSM4Cp-
I simply used a industrial standard ISA extender (doesn't matter really what, something along these lines):
https://www.ebay.com/itm/295865496399
as well as a cable:
https://oshpark.com/shared_projects/cG4aZUEg
You will need to shield the cable if you want to run the Euro PC at full speed (9 Mhz). Check out my video above at about 21.10 mins for a recommendation that works great:
@jinxter / RetroErik, that should also solve your troubles with getting the other cable / setup to work. You need to shield it.
Reply 196 of 220, by Jinxter
microtronichamburg wrote on 2024-02-11, 18:25:
Wow, I thought I had seen most videos on YouTube about the EuroPC, but i missed yours - until now.
You have rally took it "all the way". I like it.
Maybe you saw my video that i released yesterday? https://youtu.be/tuGf6ugcpkA
You solution for the degraded signal quality looks great, i will test it as soon as i get some conductive tape.
Me and Kjell Sundby are trying to create a kit for the ISA bus extension. For both 8 and 16bit. We are also planning to release everything on GitHub for those who want to create the PCB themselves.
We are glad for any input you and other might have. Earlier today i had a suggestion to use a diode to make sure that the power from the ISA back plane does not return to the PC though the cable. But a diode will reduce the volt by apx 0,5V. This could be a problem in the cased where you dont need or dont have external power.
Reply 197 of 220, by microtronichamburg
Jinxter wrote on 2024-02-11, 18:59:
Interesting. Well, in my case, I don't have the original PSU - so the backplane is powered by the same generic PSU (supplying 5, […]
Interesting. Well, in my case, I don't have the original PSU - so the backplane is powered by the same generic PSU (supplying 5, 12, -12 V; -5V is not used by the EuroPC) that powers the Euro PC - you are right, even though the ribbon cable carries power, this is insufficient to power the extension cards. Hence, I connected the same power lines from the same PSU to the backplane as well, which has power rails and nice LEDs for all of the supply voltages.
I think diodes are always a bad idea... you could just power the backplane externally with an extra PSU like I did, and simply disconnect the power lines from the ribbon cable - only connect GND. That will be sufficient. No need for any diodes. These will make everything worse.
Or, route extra cables from the EuroPC mainboard or it's power supply to the backplane extender.
Most expansion cards only need 5V anyways, AFAIK.
Good luck,
Michael
PS The YouTube algorithm systematically suppresses my comments as well as my content, I don't know why - maybe it doesn't like my last name. I am not surprised that you didn't see my comments.
Reply 198 of 220, by Kekkula
I had some time now so my Euro Pc repair attempt got a bit further.
I got it to boot by swapping non working 74F245 U3 with 74ls245, I'm still waiting for the f245 from China.
I got picture with Tseng Et3000ax. But I cant get internal chip to sync with my Philips pro 7bm743 monitor. I think that the monitor works because I can get picture when it's connected to tseng card.
I get something on the screen but text isn't readable and its out of sync, I'm thinking of replacing 74ls244 from U42 because it seems to have something to do with sync, and replacing 47pF capacitors near the video connector.
Other issue is the disk drive. I've cleaned and added some grease to it. It seems to work flawlessly but only with 720k dd disks. It formats and boots with taped 1.44Mb hd disk, but if I write to disk with other drive (I've tried several) Euro Pc drive gives me data error.
So it seems like an alignment problem. I have a faint memory of having similar problems with amiga drive, and I "fixed" it by aligning drive to 1.44Mb formated disk with amiga test kit. Is there similar program to pc where you can put the machine to read single track and then adjust alignment on the fly?
Reply 199 of 220, by DoutorHouse
Kekkula wrote on 2024-04-04, 15:34:
I had some time now so my Euro Pc repair attempt got a bit further. I got it to boot by swapping non working 74F245 U3 with 74l […]
Maybe i'm wrong but i think the Euro PC diskette drive only supported 720kb disks?
