First post, by vetz
So, got myself a NIB EIDE MAX II which I opened and started using.
I thought I bought a full IDE controller, but I got fooled. It highly recommends continuing using the existing controller for performance considerations. It adds BIOS 128GB drive support to any existing controller in your system. The IDE ports present on the card will boot a harddrive, but it will only function in real mode in Windows, which sucks in terms of performance. The manual and Amazon states they are mainly for ATAPI devices such as CD-ROM, tape and zip drives. It also works alongside my SCSI VLB controller. They also boosts about 80% higher performance over ISA (I'll see if I can bench that).
So if you know how to find a use for this card, it's great, just don't expect it to work wonders as a stand-alone IDE controller in your 386/486 as I did!
Reply 1 of 12, by hyoenmadan
Errr... you're supposed to install Promise drivers under Windows to get direct controller access to the card. It will not work with generic IDE drivers as this isn't a IDE bridge with standard memory ranges/IO ports, but a "complete" (but dumb) HBA card.
vetz wrote:
...just don't expect it to work wonders as a stand-alone IDE controller in your 386/486 as I did!
Ofc... This is a dumb Promise uncached HBA. If you want wonders, you need a smarter HBA, like Tekram IDE cached series.
Reply 2 of 12, by vetz
hyoenmadan wrote:
Errr... you're supposed to install Promise drivers under Windows to get direct controller access to the card. It will not work with generic IDE drivers as this isn't a IDE bridge with standard memory ranges/IO ports, but a standard HBA card.
The thing is that the Promise drivers do no work like this. The only thing they do is to have the card show up in device manager so you can change I/O and IRQ. They do not allow you to run the drive(s) in protected 32bit disk access mode.
This works even worse than a standard ISA controller card, as you can't get out of MS-DOS compatibility (real) mode in Windows when running a harddrive from it (which you can with any other ISA controller card). It's designed for ATAPI connections. IDE cache controllers have their own issues, like I've started to document in this thread: VLB IDE cache controllers, benchmark
Reply 3 of 12, by NJRoadfan
You are running into the brain dead esdi_506.pdr detection routines. It checks the CMOS drive types to determine whether to load or not. If you are running this card as a primary IDE controller with the onboard LBA BIOS enabled, you must set a drive type in the BIOS. The same issue happens when using the XT-IDE Universal BIOS with Windows 9x, a thread describing the problem complete with a patched XT-IDE BIOS can be found below.
http://www.vcfed.org/forum/showthread.php?514 … ndows-95-issues
Reply 4 of 12, by NJRoadfan
Also don't expect any performance boost. Its still a plain old ISA card.
Reply 5 of 12, by vetz
Thanks for the info. I'm going to try if adding a manual dummy drive in the motherboard BIOS will fix it, it actually might. I have to add, there is NO info on this in the manual, documentation or on the packagaing. It's marketed as an BIOS addon card with support for extra ATAPI drives.
It's the advertising on the packaging that claims this 😀 I benched the card today and there were a 2% performance difference, all within margin of error.
Reply 6 of 12, by firage
Good to learn a little more about the obscure IDE controller landscape pre-PCI, not a whole lot of good information out there. Thanks for doing some of the legwork lately. 😀
My big-red-switch 486
Reply 7 of 12, by vetz
Funny fact is that this piece of hardware is actually released after PCI controllers became normal, in 1997. Its main feature is to add LBA hard drive support (up to 128GB) on controllers/motherboards that dont support it natively.
I'm going to test this controller with my VLB cache controller from Promise (which does not have LBA support) and see if I can get it going 😀
Reply 8 of 12, by NJRoadfan
Promise sold a ROM-only upgrade card called the DriveMAX. The LBA ROM should work with generic IDE cards, just don't expect any sort of enabling of faster DMA or PIO modes by the EIDEMAX ROM (unless Promise added support for a few chip sets). It likely won't work with caching controllers.
The XT-IDE Universal BIOS does have support for a handful of non-caching VLB controllers, so that is always an option.
Reply 9 of 12, by badmojo
So you just plug this bad boy in next to your existing controller - leaving the HDD connected to your existing controller, and the machine will magically work with LBA HDDs? That would be something I'm interested in for my older machines with CF->IDE thingos installed - I dislike disk overlays.
Reply 10 of 12, by chrisNova777
this will work for a zip 100 + a cdrom????
does it let u boot off a cdrom? or boot from a zip-100?
http://www.oldschooldaw.com | vintage PC/MAC MIDI/DAW | Asus mobo archive | Sound Modules | Vintage MIDI Interfaces
AM386DX40 | Asus VL/I-486SV2GX4 (486DX2-80) | GA586VX (p75) + r7000PCI | ABIT Be6 (pII-233) matroxG400 AGP
Reply 11 of 12, by schlang
vetz wrote on 2016-03-28, 00:05:
thats funny because the first eidemaxx supports 32bit disk access, so why wouldn't the eidemaxx II?
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 12 of 12, by vetz
schlang wrote on 2024-12-22, 16:34:
This thread is quite old and I can't remember all the details, but I was trying to set this up in Windows 3.1. It might work better in Windows 95.
