First post, by bjt
bjt
Offline
- Oldbie
Thinkpad 370C
Dock I with joystick port on SB16 CT1770
PCMCIA Sound Canvas SCP-55
The joystick works fine normally, but as soon as I run SCPENA.EXE to enable the SCP-55 it's no longer recognised by any games.
SCPENA says that it's taken port 330h only, but it seems to also be stealing 200/201h from the joystick.
I'm using the IBM card & socket services, maybe I need to explicitly exclude the joystick port addresses.
Also need to try Cardsoft card services to see if it's any better.
Just wondering if anyone else has run across this.
