First post, by jheronimus
- Oldbie
Hi, all
I'm about to finally get myself an OPL3-enabled SoundBlaster (namely, a CT2770). While looking at the photos of the card I've noticed that there are a lot of empty spots on the PCB where capacitors and an IDE pinset should be. Compare this
and this — also a CT2770
I've also seen this on some ESS cards: just take a look at this ES1869F:
Now, I understand that manufacturers always try to reduce costs by getting rid of excess components and integrating as many feature into one chip as they can — even if that means shipping two different cards under the same model name. However, I also know that sometimes people tinker with these cards and remove capacitors and chips for their projects.
I have almost no knowledge of circuitry, which brings me to my question — how do I know if capacitors and chips are missing by design and not because someone decided to strip the card? Can you remove those components and still have a working device? Would that be visibly noticeable (e.g. signs of soldering). Hope that makes sense to you guys.
Thanks!
