First post, by Sammy
After changing Harddisk , i have to reinstall Windows 95c
Board is Intel Plato (Premiere PCI/II)
Graphics Card ist MiroMediaView+Tv Upgrade.
The Graphics Card wants an own IRQ for Mpeg-decoder and TV.
But now it is always assingned to IRQ 9.. and conflicts with Realtek Network card, also irq 9.
starting the tv Application gives now a blue screen (has worked before, on old Windows installation)
changed pci slots an removed network card... but no luck...
card has always irq9 , but irq 10 and 11 are free.
Reply 1 of 9, by .legaCy
The board bios have "PnP OS " option to enable or disable
Some PCI slots share the same irq and both of cards that are populating those slots must be compatible with this.
This board have 5 ISA and 3 pci right?
Can you give some details of how those cards are populating the motherboard slots? (Which one is PCI or ISA and which slots they are inserted)
Reply 2 of 9, by Sammy
i don't find anything about PnP-os in Bios.
Just resources controlled by "setup" or "ICU".
Its now by Setup.
i have one soundcard a soundblaster ISA with IRQ5, irq5 is reserved for ISA in Bios.
PCI slots are from bottom to top:
Miro media view+Tv
Realtek RTL8029 Network card.
VOODOO2
Do you know with pci slots share the same irq?
I tryed the MiroMedia in each pci slot alone. without voodoo2 and netzwork card.
ps: can it be the the ontrack disk manager is causing this problem?
Reply 3 of 9, by .legaCy
Well i dont really know if dynamic disk overlay can cause this kind of problems because i never had to use it.
About the PCI IRQ sharing i think that is relative to the motherboard itself(it may change for every board)
On older system its normal that PnP means Plug and PRAY 🤣
Reply 4 of 9, by Sammy
Had installed Win95 more times today and then i got it to work.
1, Install Win95.
2, Set Driver to StandardVGA (not done yesterday)
3, Install MiroMedia Drivers first (yesterday i installed Network card first)
4, Install Networkcard RTL8029 and Drivers.
5, Install Vodoo2 Card and Drivers.
Network Card and MiroMediaCard still share IRQ 9 but it works now.
Have switched cards around but i am not able to get another IRQ as 9 for any Card.
Reply 5 of 9, by Elia1995
Did you enable PnP in the BIOS at last ?
This is what (I think) helped me with my IRQ problem for the CT4750. (Although it kinda fixed by itself after like 20 re-installations of Windows 98 🤣)
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
Reply 7 of 9, by Elia1995
Have you tried again with that card ONLY in the mobo ?
Reply 9 of 9, by Elia1995
Nice !!! 😁
