First post, by Mamba
- Oldbie
Hi all,
so finally I am setting up my 940 system, using a Silverstone Grandia GD09 enclosure, I know that it is not period correct (I think) but that's what I have.
First of all I realized that the CPU cooler had to be inverted (fan blowing inside) for clearance sake, so I inverted two fan of the case to obtain an airflow that makes sense:
I will use two Raptor GLFS in RAID 0, this is the way I managed to mount two HD 3.5" on the Grandia:
Removed the two chipset fan and replaced with a ChipChilla and a Zalman (still waiting for it...), this cause a clearance problem to the VGA as you can see:
I wanted to use two GTS250 on it, but that's gonna be nearly impossible, there is no space for it, I can use only single slot VGA or two VGA with "mini" PCB, and I don't remember any GTS250 with a mini PCB.
Here with a single slot GT645 I use for tests.
This problem is annoying, I have to think for a solution.
Meanwhile this is the system (without the Zalman for the 2050 chipset), cable management is not optimal but there is not so much space to work.
Foxconn NFPIK8AA-8EKRS
Opteron 285 Dual Core (It was NEW! 🤣 )
8Gbyte RAM Samsung DDR PC3200R
nVidia GTX645 (for now)
onboard sound (searching for an X-fi PCI)
I will use XP64 Superior
