First post, by xboingx
Hi there, I'm new to this forum, previously I found here a lot of info and hope somebody will be able to help me.
I recently got a Pentium 60 with OEM version of Intel's Batman's Revenge motherboard (delivered by Polish firm Optimus).
The system works except the CDROM detection. I cannot get it to work. As I understand the board does not support booting form CD (only C and A are available in the BIOS, the documentation states so also). The board have 2 controllers, one on PCI and other on ISA, both seems to work fine, the can run Quantum Bigfoot 2,5GB (altho manually set to 1,2 GB) and it automatically detects old 42MB DM3142A HDD (but I couldn't get them to run both at once, when to 42MB disk is detected the Quantum is not, no matter the settings and cable connections). However no matter how I'll connect any working CD or DVD drive it is not detected. Neither by BIOS nor DOS (which is not surprising). I tried setting all modes to auto, switched jumpers, cables etc. The CD and DVD drives work in other, newer systems (the oldest one is a IBM P166+ system), so they should be good.
I updated the BIOS of the MB to the newest version (it had 1.00.12.AF2, I applied 1.00.12.AF2) to no avail. I tried the oldest drive I could find (mitsumi from 1997 and LG from 2003). Should I triy to find even older drive?
Any Help would be appreciated. A system without a CDROM drive is difficult to use...
Also how should I set the two disks to be available together. I did not manage to find any info on the web how to set J5 jumpers on the web.
