ODwilly wrote:Something to keep in mind with Socket 370 VIA chipsets is that due to the SB Live! Running to close to the PCI spec it can cause bus issues and even data corruption on HDD's if you are using the onboard IDE controller in conjunction with it. EDIT: (maybe that is interfering with the V2?) I have a dual P3 on a Via Apollo chipset that was used in conjunction with V2's, A V3, and a Geforce 4 ti4200 with some random compatibility issues over the years. I think the biggest issue he had was with Nvidia video cards and with the SB Live! Both of which were solved with the right chipset drivers and the latest bios version.
In the early 2000s lots of people were bitching and complaining about their SBLive cards with the KT7A. I solved the problem by using an AWE64 and enjoyed my PC without any headaches. To this day, I still refuse to use anything but an AWE64 with my KT7A systems.
Back then, I remember going through driver hell with SBLive cards on other systems. I couldn't figure out why anybody would willingly put themselves through all that trouble merely for the sake of EAX, which most games didn't take advantage of anyway. I suppose that SBLive cards are supposed to sound better than an AWE64, but I can't tell a difference.
psychz wrote:Thanks for your replies, everyone! I did use an SB Live and >256MB ram. I guess the only thing left to try is to build a system as lightweight as possible at first. I also came across this file which claims to solve SB Live corruption and other PCI bus latency issues. When I find time to actually build the machine I'll report back with what works 😀
Back in the day when all the fun was going down with SBLive cards and KT7A systems, I bookmarked this page with tons of good info regarding the problem:
http://www.tomshardware.com/forum/111739-30-h … -alleviate-686b
The page is still there. You should check it out.
Or, you know... just use an AWE64 card and save yourself all the headaches while enjoying near-100% DOS compatibility.
Anyway, I tried to look up the Asus CUV4X to see if it used the 686b southbridge. It doesn't look like it does, so you should be OK even with a SBLive card. However, there are many variants of the CUV4X, so it's very hard to know for sure. If you know the exact model of CUV4X that you're using, it will be easier to look up its specs.
Jade Falcon wrote:SRQ wrote:
1: Do not use more than 256MB of ram. The main issue appears to be the Voodoos memory space.
odd my voodoo 1 and voodoo 2 did not have problems with 6gb of ram in the newer x58 system I tried them in.
I would be interested in hearing more about your Voodoo 1 in such a system. Most folks have trouble running them with CPUs faster than 600mhz. What games have you tested? Did any fail to run? In particular, Incoming and Expendable are known to choke with CPUs faster than 450mhz.
