The Soundblaster DSP project
Reply 800 of 1053, by mattw
Maelgrum wrote on 2023-10-07, 21:31:
Something like AT89C51ID2-SLSUM or AT89C51ED2-SLSUM, but pins compatibility shold be checked.
then I think 'AT89C51RD2' is another candidate - easier to find and cheaper to buy.
[EDIT] 'AT89C51RC2' is even cheaper...
Reply 803 of 1053, by Imito
what if the dma clicking is not related to the DSP?
aren´t capacitors used to filter audio too? Creative could messed up the caps values from factory?
just thinking...If there is a click on an audio that is expected to have a high pitch.
This website provides audios from different cards, showing all the noises, clicks, Pops, and they even talk about the ct2940 a card that has with DSP 4.13 as being one of the best ones with less issues.
http://nerdlypleasures.blogspot.com/2015/05/1 … t-playback.html
Reply 804 of 1053, by maxtherabbit
S95Sedan wrote on 2023-10-07, 21:47:
maxtherabbit wrote on 2023-10-07, 21:46:
S95sedan, do you think the clicking is improved in this test build?
Not really to be honest, if it is very very marginal.
I agree. It's either a small improvement or the same, not major
Reply 805 of 1053, by maxtherabbit
Maelgrum wrote on 2023-10-07, 20:15:
If it works, look at single cycle dma
did this build also fix the thing with saving the flags register? I didn't see you mention it lately
Reply 806 of 1053, by Kahenraz
I was under the impression that all of the Vibra chips had an integrated DSP. When examining a CT3930, I see what looks like a small ROM chip. Is it possible that the DSP can be swapped out from this chip? What else could it be?
204.17 KiB
19.09 KiB
Reply 807 of 1053, by TheMobRules
Kahenraz wrote on 2023-10-08, 04:44:
I also have a 3930 and was wondering the same, on my card that chip is covered by a label that says "(C) CREATIVE 0148393000" which I didn't want to remove. Unfortunately I don't think it's the DSP, it would be kind of pointless since it's supposedly integrated in the CT2501. Which is a shame as the CT3930 is an interesting and peculiar card, the non-PnP + Vibra + Real OPL + EMU8000 combo makes it really unique... a bug-free DSP would make it the ideal SB16 IMO.
By the way, the DSP chip is actually a microcontroller, not a ROM.
Reply 808 of 1053, by mattw
TheMobRules wrote on 2023-10-08, 05:17:
that's not the DSP, you can find almost the exact same chip marked as "0148291000" on the older non-PnP cards (like CT2910, which has discrete 8052 MCU on-board) and located on the same place - as that chip is directly 'wired' to the ISA connector gold-fingers my best guess is that's "bus address decoder" that gives access to OPL, EMU8K respective IO port via the ISA bus.
[EDIT] you can even spot a pattern how that chip marking is constructed based on the model number:
0148 XYZT 00:
CT2910 --> 0148 2910 00
CT3930 --> 0148 3930 00
Reply 809 of 1053, by Tiido
That chip is a PAL/GAL type thing for address decode purposes, and yeah, most probably for EMU8000.
Reply 810 of 1053, by DerBaum
mattw wrote on 2023-10-08, 09:39:
that's not the DSP, you can find almost the exact same chip marked as "0148291000" on the older non-PnP cards (like CT2910, whic […]
0148 XYZT 00:
on my ct3600 the chip is just covered with a sticker.
the sticker covers up that it is a ct2290 chip.
217.32 KiB
maybe thats of interest.
FCKGW-RHQQ2
Reply 811 of 1053, by mattw
DerBaum wrote on 2023-10-08, 11:11:
it looks like Creative totally cheap-out, since its PAL (i.e. programmable) chip, it seems they had old re-marked chips left-over from CT2290 cards and reprogrammed them.
Reply 812 of 1053, by mkarcher
mattw wrote on 2023-10-08, 11:34:
The custom marked PALs usually are OTP or mask programmed, so they can't be re-programmed. To me, it looks like the chip is not for EMU8000 decoding, but for IDE port decoding. And the IDE interface on the CT2290 and the CT3600 might be identical. The bus interface chip of the CT3600 is PnP capable, so it needs to provide the I/O address base selection signals to the PAL, while on the CT2290, the IDE base port is configured using jumpers. I suppose the sticker is just to "clean up" the number so it matches the card, not to indicate that it has a different program.
Reply 813 of 1053, by maxtherabbit
Does the third "4.13 maelgrum" release fix all known bugs so far in 4.13? I'm gonna burn it to all my cards and call it done if yes. I've given up on seeing single cycle DMA get fixed in firmware, don't think it's possible
Reply 814 of 1053, by Maelgrum
maxtherabbit wrote on 2023-10-09, 16:34:
Don't despair, i have some ideas about single cycle DMA, but large scale fw rewrite is needed, so it takes some time.
Reply 815 of 1053, by Maelgrum
third release:
1. Hanging note bug fixed
2. Some ADPCM decoding bug fixed
3. Small speed-up of fw code, but not solving Single DMA bug
Reply 816 of 1053, by maxtherabbit
Maelgrum wrote on 2023-10-09, 17:18:
third release: 1. Hanging note bug fixed 2. Some ADPCM decoding bug fixed 3. Small speed-up of fw code, but not solving Single D […]
third release:
So no fix for the flags register not being pushed to stack before interrupt?
Reply 817 of 1053, by S95Sedan
These are the fixes that are out there?
v413-8k_4ca3dca8_patch3
- Fixed hanging note bug
v413-8k_16a46526_patch4
- Fixed PSW bug in ExtInt0/ExtInt1 interrupt handlers
Id just go with the last one for now.
Theres a couple things which can be improved but it will probably take time.
Here im mostly cleaning up the code before doing anything, making it a bit easier to work with.
Reply 818 of 1053, by maxtherabbit
S95Sedan wrote on 2023-10-09, 17:21:
These are the fixes that are out there? […]
When I said "third maelgrum release" I was referring to the ones made by assembling modified disassembly from the dumps, not the hex edited versions. Also you forgot the ADPCM fix
Reply 819 of 1053, by S95Sedan
maxtherabbit wrote on 2023-10-09, 17:25:
You mean the typo in X1231? Thats all i can see as changed in the later versions.
mov	a,0ffh
to
mov a,#0ffh
