First post, by jheronimus
Hi, all
I'm thinking of getting a steering wheel for a P166/Voodoo 1 machine. I've never actually owned a wheel and I don't think I'll be into some serious simulators. I just want to get something comfortable to play Carmageddon, Quarantine, Need for Speed, etc. So, a couple of questions here:
1) Thrustmaster FCS and CH Products were something of a standard for joysticks. Many games supported them out of the box, other manufacturers tried to emulate them for better compatibility. Same goes for Gravis and gamepads. Is there anything similar with wheels?
2) Is force feedback support common in games around 92 to 97?
3) Am I correct to assume that in many cases wheels actually emulate a joystick, and if a game supports a joystick, it will work with a wheel?
4) Which model would you recommend?
All in all, I'm thinking about getting a Microsoft Sidewinder Force Feedback. I really like my Sidewinder 3D Pro for its ergonomics, design and build quality, and I kind of like the design of Force Feedback. Does anyone have any experience with it? Is it well supported in the games?
Thanks!
MR BIOS catalog
Unicore catalog
Reply 1 of 11, by badmojo
I've never gone past my trusty Thrustmaster GP1 - the one with paddles on the wheel instead of peddles on the floor, which are more trouble than they're worth IMHO
Reply 2 of 11, by jheronimus
Why? Seems a bit counter-intuitive. Are peddles too hard to press or something?
MR BIOS catalog
Unicore catalog
Reply 3 of 11, by y2k se
A steering wheel and pedals are basically like a joystick with a slightly different interface. Any racing/driving game will be fine with a gameport wheel on the machine you're saying you'll be using.
For reasonable prices, Thrustmaster is going to be the go-to option for steering wheels of the era. The MS SideWinder Pro Force Feedback is too new for a P166 machine (I have one in the closet) as nothing will use the force feedback and you will have a better feel with a true centering spring on those old games. The GP1 badmojo posted is a fine wheel, but the paddles for the brake and gas are limiting because they are on a combined axis. This means you can't gas and brake at the same time. I would highly suggest getting something that supports separate axises for brake and gas.
I have some variation of the Thrustmaster NASCAR Pro wheel for my retro PC and it works great for the old DOS Papyrus sims and NFS.
Tualatin Pentium III-S 1.4, ASUS TUSL2-C, 512MB RAM, GeForce 4 Ti 4200, Voodoo2 SLI, SB Live!, 3Com 3C905C, 80GB IDE HDD, Dell 2001FP
P233MMX, Intel LT430TX, 64MB RAM, Sierra Screamin' 3D, AWE64 Gold, 3Com 3C905B, 40GB IDE HDD, Viewsonic A75f
Reply 4 of 11, by badmojo
Extra cables, more things to go wrong but more importantly I never found them comfortable to use. They slide away when you stomp on them and feel nothing like actual car peddles anyway. The paddles on the wheel on the other hand are comfortable and accurate all day long.
Reply 5 of 11, by jheronimus
Any opinions on the Thrustmaster Formula Sprint?
Looks similar to NASCAR Pro (not sure about the specs/functionality) and I can source one pretty cheaply.
MR BIOS catalog
Unicore catalog
Reply 6 of 11, by y2k se
I'm not familiar with that one. Looks like its just missing the shifter and the pedal base is a bit different. Otherwise its probably about the same.
Reply 7 of 11, by chinny22
Did you get this in the end?
Reply 8 of 11, by jheronimus
Nope. I've decided to wait and research a little more. To be honest I can't get over its looks — just seems a bit too spartan and cheap — more like Quickshot.
Could very well be that because wheels of this era simply weren't as popular as joysticks, vendors did not put too much thought into their design.
MR BIOS catalog
Unicore catalog
Reply 9 of 11, by chinny22
ok thanks,
Keeping 1/2 eye out myself for a good dos wheel. Had a Mad Catz wheel back in the day, but even then it felt cheap and didn't last that long.
Where as 9x and above your have plenty of choice (Love my Wingman Formula Force "big red" not the crappy GP)
