First post, by clueless1
- l33t
From what I've read (http://www.playtool.com/pages/psuconnectors/c … tors.html#oldpc) AT motherboards relied heavily on the 5v rail compared to ATX-powered mobos. The chart on the link above suggests 15-20A for the 5v rail.
I'm putting together a 486 PC in an ATX case with ATX to AT converter for the PSU. What minimum specs are recommended for the ATX PSU that will be powering this 486? It seems a minimum 15A +5v rail? Does that sound about right, and are there any other recommendations?
Thanks!
