First post, by kixs
- l33t
Wanted to test a few Slot-1 cpus and found out that none of my three motherboards would POST - they get the power, CPU fan is spinning. Otherwise they look like dead - no beeps or anything.
Since I use the same ATX PSU for all I guess it must be something wrong with it. Although it powers s370/s462/s478 motherboards just fine.
What should I check with PSU that it's Slot 1 compatible?
