First post, by Melonking
- Newbie
So I just booted up my first socket 7 build today, everything went well, system started up. Yay! But something is perplexing me.
Im running a Pentium 1 100mhz cpu on a FIC PA-2013 motherboard.
The cpu is recommended at a 1.5 clock multiplier, the motherboard states it supports the cpu and mentions it many times in the manual. However the board does not seem to have an option for 1.5 as a multiplier.
CPU spec: www.cpu-world.com/CPUs/Pentium/Intel-Pe ... 2100).html
Manual:
I currently have it set to 3.5 as it says that counts as 1.5 for AMD cpus, and it works fine. But I'm worried I could be doing damage if this is not correct.
