First post, by MrEWhite
So, I have a GA-6VTXE and a Pentium III 1.4 GHz. If I have it at 1.4 GHz (133 FSB) games like Quake has "snowy-lines" (like here: http://i.imgur.com/AAwFNWdh.jpg) only at 320x200. At 100 FSB, only Terminal Velocity has the snowy lines. Is there a fix for this?
Reply 1 of 7, by Ozzuneoj
I would guess that the high frame rates at lower resolutions with such a fast CPU is exposing some kind of flaw or defect in the Voodoo 3... it may just be overheating.
Reply 4 of 7, by Ozzuneoj
Is it a PCI or AGP Voodoo 3?
If its AGP, try disabling the various AGP related bios settings, like Fast Writes. Set it to 1x AGP, etc.
Reply 5 of 7, by MrEWhite
It's AGP. And my BIOS only has the AGP 1x,2x,4x options related to AGP.
Reply 6 of 7, by Jade Falcon
Rank BANNED
BANNED
The voodoo3's have trouble with over clocked bus speeds like most 3dfx cards. Depending on you board your agp bus might be overclocked at 133fsb. Look and see if your bios have a option for changing the agp bus dividers.
Reply 7 of 7, by MrEWhite
Nope, mine doesn't. So I'm going to have to stick at 100 FSB then?
