First post, by TheMobRules
So, a few weeks ago I got an old PC that was discarded from an office. I mainly got it for the case (a nice AT case with MHz display and turbo button, in pretty good condition), but when I was disassembling it to clean it I found it had one of those awful PCChips "TX Pro-II" motherboards, with a K6-2 300 and 64 MB of PC133 SDRAM.
I haven't had the time to test it yet, but according to the guy who gave me the machine, it was still working well when they last used it. And other than a couple of dubious capacitors everything looks fine on visual inspection. This is the board:
However, when I looked at the back of the motherboard I noticed something unusual. It seems two of the pins in the CPU socket are bridged together by a small piece of metal:
Now, I don't know if this is some kind of factory "fix" or someone did some kind of mod to the board after purchase, but maybe someone who is well-versed on this could know if this was a common thing back then? I don't have anything like this in my other Socket 7 boards, so I was wondering what bridging those two pins could accomplish. 😕
Reply 2 of 5, by TheMobRules
h-a-l-9000 wrote:
It looks a bit like a capacitor
You're right! I hadn't noticed it at first because it is mounted on its side and it looked like a thin metal bridge. But watching closely I see that it is indeed an SMD capacitor...
So, I guess everything points to this being a factory fix after all.
Reply 3 of 5, by Imperious
That PCChips model is known as being quite good, and will run at 500mhz 83x6 with a k62+ or k63+ cpu with the right bios installed.
http://m571.com/m571/
PC's from XT 8088, 486, Pentium MMX, K6, Athlon, P3, P4, 775, to current Ryzen 2600.
Reply 4 of 5, by TheMobRules
Very interesting, thanks for the info!
Now I want to fire up this board and see how it performs! 😁
Reply 5 of 5, by FGB
That's only half of the truth! You forgot to mention that you have to get a stable one first! Many of the earlier revisions are unstable, even at 75MHz FSB, forget about 83!
And even those of the last revision do not gurantee you stable 83MHz, but usually work fine when set to 75MHz and the PCI divider set to 2.
www.AmoRetro.de Visit my huge hardware gallery with many historic items from 16MHz 286 to 1000MHz Slot A. Includes more than 80 soundcards and a growing Wavetable Recording section with more than 300 recordings.
