Thanks for comments.
Well, it arrived today. It looks in pretty decent shape but they did a poor job packing it and it received a dent in shipment. I'll live... The front panel plastic all looks good though and I think it will cleanup nicely. I like the size of it and the layout looks good.
The spare motherboard I ordered should be in within a few days.
I have ordered an Intel E8600 (3.33-GHz) CPU for it just to max it out, I finally saw one at a decent price.
I plan to install 4GB of Crucial DDR800 that I already have on hand.
The X-Fi SB0880 arrived as well and I am ordering an extension cable to plug the front panel audio from the case into the X-Fi's front panel connector. http://www.newegg.com/Product/Product.aspx?It … N82E16812201025
I think I will use a SeaSonic G Series SSR-550RM 550W PSU which receives good reviews, not crazy expensive and is made by favorite maker of PSUs. This should power the single GTX 285 easily and just in case I decide to install a Q9650 CPU later to dual boot Windows 7. The case doesn't look like it will need any modification to install the PSU. Once installed I will report back.
I even ordered a XP case badge sticker to replace the Vista badge sticker... hehe. If the case were in printine condition (it isn't) I would order a new XP COA for it.
I am about to look at options for new case fans to replace the originals. I haven't tested the originals yet but those fan bearings don't last forever.
I am holding off ordering any hard drives for it until I get a chance to test everything and get it up and running. I will use whatever I have on hand in the meantime.
This may be my favorite OEM system for XP thus far. I really like the layout, the looks and what it has to offer. Front panel audio and USB are in a perfect location, installing a double slot PCIe graphics card and a PCIe sound card still give you one empty slot between the two, thermal design looks good with push/pull air induction (most HP's similar to this use same type design), plenty of room for any size double slot graphics card, and did I mention I like it?
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
