First post, by oeuvre
Hi all,
I have an NEC Ready 9616 and I believe it uses an LPX motherboard layout. i was wondering if I could put a different LPX style motherboard in the case and just use everything else in there... the current mobo is a bit wonky.
Would any LPX mobo work? And can I reuse the riser card? Here are some pictures http://imgur.com/a/gzT4P
Reply 1 of 3, by BSA Starfire
Sadly it's not that simple, LPX was never a standard set in stone. Sometimes you can get away with swapping boards with systems from the same manufacturer, series but even that is not a given. Risers are usually only usable in the board they came from, there is a lot of variety.
Your best bet is trying to iron out the problems with your wonky board I suspect. If that doesn't work out then a like for like replacement.
Good luck and let us know how you get on.
Best,
Chris
Reply 2 of 3, by luckybob
+1 for what BSA said.
I'm willing to bet $20 nothing is going to work in a case like that expect a similar model board. i.e. maybe a mobo from a 9626 will work. (for sake of argument)
Risers will always be unique, the screw holes will be different, power connectors will be wired different and or have non-standard connectors. The list goes on. Best advice? Repair the board you have, or get a new one. You mentioned the board is "wonky". Check for bad caps. These were mid 90's machines? 20+ years old now. Doing board re-capping is a extremely common thing to do.
Reply 3 of 3, by oeuvre
Alright... thanks. I'll just see if I can unload the thing on ebay... doesn't really have any interesting parts in it for me anyways. Thanks all
