First post, by computergeek92
I fix up my unwanted computers to sell online. I have a SATA 1 PCI card laying around. It's a TR-822 (ver 1.0) 2-port card. The system in question is a Socket 5 Micron MPC with a 100MHz Pentium and 16MB ram. If I bump the ram to 64MB and plug in a 20GB or 40GB SATA hard drive, will it work with Windows 98SE? I see some drivers for it on driverguide.com but I haven’t tried them yet.
Dedicated Windows 95 Aficionado for good reasons:
http://toastytech.com/evil/setup.html
Reply 2 of 3, by synrgy87
if you're very lucky the bios may detect it as a SCSI controller, but doubtful it'd work on a socket 5 board you may not be able to boot from it, an alternative would be to use SATA to IDE adapters which are relatively cheap.
Reply 3 of 3, by bhtooefr
Also note that you may have to mess with the BIOS config a fair amount to disable booting from the onboard IDE controller, to make it use the option ROM.
But, only way to find out is to try it.
