First post, by 386SX
Hi,
after all the years I still have doubts on the AGP voltages story from my memories with the introduction of the AGP 3.0 8X interface that would only give 0,8 or 1.5v to the card.
First theoretical problem: as it's written on some boards there's specified to not put a 3.3v card into a AGP 8X connector cause the mainboard would theoretically be damaged by it (never understood why by the way, being expecting an higher voltage would the card just not boot? and anyway why don't put some protection to just not boot it?).
Second one: an AGP 3.0 8X card would be damaged in an AGP 1.0/2.0 mainboard case cause the mainboard would give 3,3v exceeding the 1,5/0.8v card specification.
Considering these two problems I would ask: an AGP 1.0 1x/2x 3,3v compliant card couldn't be fitted on a AGP 3.0 mainboard cause the connector should not permit it. So did the problems come with the cards that could theorically have only 3,3v specifications BUT with AGP 2.0 1x/2x/4x opened connector?
I have seen some cards that could have had that, for example some Savage 4 cards had the closed AGP 1x/2x connector others had the opened 1/2/4x. But the company that built them could have used that connector cause they regulated the right voltages on board?
So returning to the words written on my mainboard "3,3v AGP card will cause permanent damages", why this would happen if the 3.3v cards had the closed connector?
I can imagine that the real problems came with the transition from 1x/2x to 1x/2x/4x connection when some could use the opened connector without regulators.
Thank
Reply 1 of 9, by stamasd
This is the bast site that explains it:
AGP compatibility for sticklers
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 2 of 9, by 386SX
I was reading some specifications on the G450 AGP and Parhelia 128MB AGP official legacy site and maybe I think I understood it right. Both cards has the usual opened 2x/4x socket,
BUT the G450 has specified this: AGP 4x, compatible with all AGP slots (0.8, 1.5, or 3.3 V)
the Parhelia 128MB has specified this: AGP 8x, compatible with all compliant AGP 4x and 8x systems (1.5 or 0.8 V)
So could the second card be damaged on an older AGP 3,3v only mainboard, while the first will not in any mainboards?
Reply 3 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Maybe if somebody was trying to force the card into the slot? (And yes, such elephants do exist)
1+1=10
Reply 4 of 9, by 386SX
I think more the case where some manufacturer could use the AGP2.0 opened socket on a 3,3v only design. In that link they seems to think the idea of "any cards that fit should be ok" is not true.
The only way to know should be measuring the voltage the socket is actually giving to the cards but also we would not know if that voltage is regulated after or not. By the way I am trying a G450 AGP on the KT600 AGP8x board and it's running ok until now.
Reply 5 of 9, by Matth79
As it says, some manufacturers did violate the keying specifications, most likely a 1.5V only motherboard being keyed as "universal".
Also, some chipset / card combinations can be tricky, failed to work with a savage 2000 card in an AMD750 chipset motherboard, but then the AMD750 is not the greatest AGP chipset!!!!
Reply 6 of 9, by Carlos S. M.
Well, i found a quite strange motherboard, an Abit SG-72 which is based on the SiS 661FX chipset, but aparently it has an universal AGP port (SiS 661FX motherboards usually have 1.5/0.8 keyed slots). I just decided to pop some 3.3 v cards on that motherboard and none of them didn't work, one did actually made the system POST, but it was only a mess of random characters
The Abit SG-72 supports FSB 800 Northwood and Prescott P4s with HT, AGP 8x, DDR400, but is still quite strange an universal slot on that kind of motherboard. I haven't tried other cards nor universal/1.5/0.8 v only cards yet
Reply 7 of 9, by PhilsComputerLab
Rank Hardware Mod
Hardware Mod
I have some P4 boards with universal AGP too. Some work fine, they are compatible, the other ones won't post. One even has a warning LED if you put in the wrong card.
The documentation usually tells you if it's compatible or not.
YouTube, Facebook, Website
Reply 8 of 9, by Carlos S. M.
There was nothing about 3.3 volt cards on my Abit SG-72 manual afaik. I know most older P4 also featured universal AGP slots (mainly SiS and VIA chipsets), but mainly, they only usually support AGP 4x, DDR up to 266 or 333 and only 400/533 FSB CPUs without HT (a few of them suspported the 3.06 Ghz HT model though), but my Abit is quite different... DDR 400, AGP 8x, FSB 800 Northwood and Prescott support.
I still need to do futher tests on that Abit
Reply 9 of 9, by PhilsComputerLab
Rank Hardware Mod
Hardware Mod
Yea in the manual or in the specifications. If it doesn't mention anything about 3.3V than likely it doesn't support it. Though I found many boards with that clearly being mentioned. Mostly AOpen boards though. I don't have anything from ABit with SIS chipset...
