swaaye wrote:
SBLive also has noisy front output. Vortex 1 cards like Turtle Beach Montego have better signal quality, and a MIDI daughtercard header that works in DOS. Frankly I wouldn't even consider SBLive. Go for an Audigy 2 instead for your EAX needs.
As much as I love Aureal hardware, there are more pros than cons using a Live over the Vortex 1. EAX and A3D 2.0 were the API top guns and everything else wanted/had to be compatible to them.
For audio quality the Aureal cards are very clean, but if audio quality is a major concern then why choose between these two when there are far better alternatives?
I infer the most important is the gaming support from "gaming soundcards", everything else is secondary.
There are lots of A3D 1.0 games, and there are also an equal amount of EAX games. The Live supports HRTF for A3D 1.0 games, and also allows you to run EAX games as well.
The Vortex 1 has no reverb support, just really clean positional audio done in software (no hardware HRTF on Vortex 1's).
The drivers on the Live are more mature than the drivers Aureal put out. More games of a later time frame are supported that will work on a Live that a Vortex 1 will struggle with, e.g. Unreal 2 with EAX and 3D audio on a Live works fine, where as the Vortex 1 will not produce 3D audio or reverb due to the lack of support in the title.
For the time period (96') that the card was released, it was a great contender to every other soundcard. If their ADSP301 CoProcessor was ever released it would have brought reverb and extra audio channels to the card making it then much better than the later Live (in general).
The only reason one should every use one of those cards is if you couldn't get something better.
I would only keep those cards for reference and dev work, but would otherwise go straight for an Audigy 2 and/or a Vortex 2, since those should be the starting point of any recommended PCI gaming soundcards.
A card like the Santa Cruz tries to be the best of all worlds thanks to its Sensaura backbone, and it does a great job of it! Highly recommended card.
