First post, by GuyTechie
I've never seen a CT4520 that's neutered:
http://r.ebay.com/JSOYok
No wavetable header? Huge blank space!
What a normal CT4520 looks like:
Thats an OEM card. An AWE card without the AWE 😁 = A SB16 card. I don't know if it was Dell or Packard Bell who built them into their entry lines.
www.AmoRetro.de Visit my huge hardware gallery with many historic items from 16MHz 286 to 1000MHz Slot A. Includes more than 80 soundcards and a growing Wavetable Recording section with more than 300 recordings.
yeah i don't quite understand why they made this. the midi synthesizer part wouldn't work without that sample rom chip, but if they want a sb16 equivalent, the highly integrated vibra16 is a solution with lower cost.
Buyer beware for certain. I suspect Dell or whoever didn't care for Dos usage so removed parts to make it cheaper.
They obviously had no idea as could have used a sb16 value, but they likely still marketed this as AWE64 regardless.
Maybe the Midi part still works under win95/98 though?
wrote:Buyer beware for certain. I suspect Dell or whoever didn't care for Dos usage so removed parts to make it cheaper.
If you set Win9x to use software synth, then yes it would still work...
This topic is old but we can update news found here:
AWE64 problem-- no music in DOS
This card is Sound Blaster 16 WavEffects with software synt under windows. Is labeled CT4520 but listed as CT4525 in official List of Creative Sound Blaster Products:
http://www.ask.asia.creative.com/wwenglish/ge … _list_audio.htm
Box photo is here:
http://www.pixelatedarcade.com/tech_attribute … und-blaster-16/
(For confusing second SB16 WavEffects card was different small board CT417x with simple Vibra16 chip)
