First post, by Bancho
- Oldbie
Hi All,
Anyone have any experience passing audio through the line in on an Audigy 2 ZS in dos? I would like (if possible) to pass the audio through my Yamaha card through the Audigy's line in so i can utilize the live drive i have installed.
I have tried using a cable to run the audio from the line out on the Yamaha Card into the Audigy's line in but i get no sound, which i imagine because the line in not active due to no drivers installed. Am i going to have to wrestle with drivers for the Audigy? If that's the case is it really worth it as i imagine it's not going to be straightforward 😵
