First post, by RetroStorm00
Hey all, I have a QDI V4P895P3/SMT V5.0 motherboard. Im trying to use a sx955 P24D dx2 chip, problem is if is close JP7 pins 1&2 for P24D WB mode the motherboard will not post, if I close JP7 pins 2&3 for P24D WT mode the motherboard posts just fine.
The motherboard also works fine with other 486 CPUS I also tried a standard sx911 chip and it worked just fine.
I used the motherboard pinouts from this page: http://www.elhvb.com/mboards/qdi/895p3s5.pdf
Anyone have any ideas? 😵
Thanks!
Reply 3 of 7, by PhilsComputerLab
A shame because I'm eager to see what this Enhanced 486 can actually do in games. WB L1 CPUs are a bit harder to find, yours is the only Intel DX2 66 I believe.
YouTube, Facebook, Website
Reply 4 of 7, by clueless1
If you could find a username and password, you might be able to access QDI's ftp via the wayback machine:
https://web.archive.org/web/19970130115152/ht … ml/bios.html#p4
Reply 5 of 7, by RetroStorm00
Ya they are a bit tough to find, found mine from a seller advertising it for gold scrapping. The pins were quite bent but I fixed those..I think I paid less than 10 usd for it. Motherboards are providing to be more of a PITA, the Asus 486SV2G0 only supports it with certain revisions and now this QDI board is refusing to work, Im beginning to wonder if its even worth it 😵
Reply 6 of 7, by Agent of the BSoD
It seems someone with a similar board had the exact same issue a while back, but it went unsolved: 486 motherboard problem: QDI V4P895P3 / SMT V1.0 mobo won't POST in write back mode
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | SB Pro 2 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
