First post, by James-F
I use a boot menu to choose between UMBPCI or EMM386, but I don't want to reboot or load EMM386.
Can it be done?
Reply 2 of 10, by stamasd
Jemmex/Jemm386 (part of FreeDOS). It can be loaded/unloaded from the CLI.
http://www.freedos.org/software/?prog=jemm386
http://www.ibiblio.org/pub/micro/pc-stuff/fre … emm386/jemm386/
There's also a very old utility called emm286 that can create EMS from XMS without placing the CPU in protected mode and works on pre-386 CPUs; the problem with it is it can't use UMBs for the frame page and thus can only create the page in conventional memory which severely reduces its utility. If you have a program that requires EMS on a 286 and doesn't use more than about 530k conventional memory, it could be useful. It also can be loaded/unloaded from the CLI as far as I remember.
http://www.pcorner.com/list/UTILITY/EMM286.ZIP/INFO/
http://www.pcorner.com/list/UTILITY/EMM286.ZIP/EMM286.TXT/
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 3 of 10, by clueless1
Sounds like an Ultima Underworld spell: "Create EMS"
Reply 4 of 10, by James-F
Thank stamsad.
I'm trying to load Jemmex with LOAD NORAM using the command line but I keep getting a "XMM already installed" error.
All I need is simulated 16MB of EMS from my XMS without loaded UMB or activating XMS once more.
Any idea?
Reply 5 of 10, by stamasd
Jemmex is a combination of XMS and EMS driver. If you have himem.sys already loaded it won't work. 2 suggestions:
1. don't load himem.sys, use only jemmex
or
2. if you want to keep himem.sys, use jemm386.exe instead of jemmex.exe. Jemm386 is just the EMS driver.
I/O, I/O,
I/O, I/O
Reply 7 of 10, by Cyberdyne
http://www.emsmagic.com
Nifty modern and free program.
Reply 8 of 10, by stamasd
Nice find! I didn't know about that one. Looks like it doesn't need virtual386 mode, and the frame page is very flexible. But because of those 2 things, it's also likely to be slower on real older hardware than emm386, qemm and the like. It;s also not compatible with 286 because it uses 32-bit code.
I/O, I/O,
I/O, I/O
Reply 9 of 10, by James-F
Amazing! Thanks you so much Cyberdyne.
This is an absolute must for people who want to load EMS memory without EMM386 and already use UMBPCI.
It even loads itself into UMB if there is 64KB free UMB block.
Reply 10 of 10, by matze79
There's also a very old utility called emm286 that can create EMS from XMS without placing the CPU in protected mode and works on pre-386 CPUs; the problem with it is it can't use UMBs for the frame page and thus can only create the page in conventional memory which severely reduces its utility. If you have a program that requires EMS on a 286 and doesn't use more than about 530k conventional memory, it could be useful. It also can be loaded/unloaded from the CLI as far as I remember.]
It also supports no DMA Transfers (Slow)
