First post, by Reputator
- Member
My motherboard is Socket 462 running a VIA KT133A chipset. It has one ISA slot, and it's the only board I own with one. I bought a CT2940 which exhibited crackling in the right channel when playing PCM sound effects (FM music seems fine). So I bought another one since they're cheap, and it does the same thing.
IRQ is set to 5, Low DMA 1, High DMA 5, Address 220. Motherboard's onboard sound is disabled, BIOS defaults reset multiple times (PnP feature has to be disabled for the sound card to even work). I'm running Windows 98 SE with drivers from VOGONS.
Here's a sound recording of the issue:
https://soundcloud.com/nathan-mayer-387886261 … ct2940crackling
I tried both speakers and direct headphones connected. Tried both line-out and speaker out. Tried disabling all integrated peripherals. Different graphics cards in case of interference. I'm starting to wonder if there's some quirky compatibility issue with my board. Has anyone encountered anything like this?
