First post, by 21603
- Newbie
I've tried everything I can think of to test this and all suggestions I could find on here, but nothing appears to be working.
This thing has been in storage for a few years, but it was working before that because I installed XP onto it and loaned it out. I never tested it when it returned, but I don't think they ever used it.
They other day I dug it out of the wardrobe along with my Pentium DOS machine (which works thank god!) and booted it up and nothing happened. I changed the video card from the AGP S3 Trio in it to a PCI Tseng something still nothing. It was at this point that I went straight from annoyed to rage and stripped it. I took the PSU down to the shed and tested it, the numbers came up normal so I assume it's fine. I took the opportunity to give the whole machine a clean although it wasn't really dusty.
After plugging it all in and running bare-bones it finally decided to give me some feedback and beep. At this point only the main power was plugged in with the CPU. I got beeps indicating a RAM error. Plugged a stick of RAM in and booted again. Video error this time, I was finally getting somewhere and I was back down to just being annoyed. I plugged in the AGP card and the monitor and Satan's bastard child decided to boot and give me a display. RAM tested OK with the usual errors for everything else all over the place.
I was pleased with this result so I turned it off and on a few times to see if I just didn't get lucky and it booted every time. Next logical step was to start putting everything back, so in went the hard drive and associated cabling, screwed in the video card and booted.
Back to square one!
Silence is golden, but in this case it just enraged me again.
No display. No beeps. Nothing all over again.
I'm not sure who or what bought it back to life when it booted, but I want the power. The strangest thing is it will and won't work. Sometimes it will beep that the display is missing, but usually it just sits in the corner and stays quite.
After a final test tonight I think I've really pissed it off. I tested again with the Tseng PCI video card and it just displays a solid green colour. I know the card works because I pulled it from my DOS machine and it works fine. With the AGP card in I get nothing or beeps indicating a missing video card. Now all I get after this final test with just the CPU and/or the RAM is silence again.
Could I be missing something. I've taken a picture of the board in question. I couldn't find a brand or much of anything else so I have no idea what it is. I also looked over it, but couldn't see anything wrong like cracks or dry solder
Not the best picture. The front reads 6BZ N1497 (I think they're meaningless), the back has what looks like a logo LH with a a circle behind them. The numbers next to it are M6 94V-0. On the left side of the board below all that is written SP-6BZ REV:B. That's all I could find.
All the issues seem to point toward it being the motherboard, but I could be wrong.
If it is the motherboard then I can expensively replace it with one from Ebay. Two Slot 1 Pentium II boards are up for grabs on my local Ebay at the moment, but if that's not the issue then I'll have wasted some money. The more expensive board is also much newer with a built in I/O panel and would require my other much larger crappy case.
The cheaper one at least comes with a CPU so that would give me a spare to test with at least.
