First post, by tangles
Hi there,
I'm new to the forum so hope I've put this in the right place 😀
I recently picked up a new old toy. It's an Ipex built system with an FX-3000 motherboard (dual socket 386/486 board, but this one only has the socket for 486), 486 SX 25mhz, 8x 1mb of simms, and a trident VGA card. I've added an SB16, picked up an AT keyboard, ordered a serial mouse and am looking around for a suitably-beige CD-ROM drive to add to the mix.
I also have here a Texas Instruments 486 DX2 80. That clock rate seems too high for the board, but I was hoping to get it into the FX-3000 running at 66mhz. Does anyone know if it's OK to run at a lower clock rate?
I've uploaded some piccys of the system here, which I took while stripping it down for a good clean up 😀
-dead link-
Cheers
Tim
Reply 1 of 2, by Brickpad
That is quite a unique case, and a bit unusual with 6 LEDs. Interesting to see that 2 of them were for two separate hard drives. Not sure what the Aux(illary) LEDs would be for?
Reply 2 of 2, by luckybob
That is a speed double processor. You mentioned on your site the FSB options are 25/33/40/50/66. So whatever you select, the processor will run at 2x fsb. 486 boards are hit and miss on quality. the origional 486-50 was "rare" because so few boards would run at 50mhz fsb. Long story short, you are going to want to stay with 33 or 40 fsb at most. 50+ will require additional work and likely wont be worth the effort. (faster cache, better ram, etc)
That said, the ti chip is a nice one, if possible attach a small heatsink. Nothing too powerful, but Its something I recommend to everyone.
Also, hello!
*EDIT*
Also Your board is limited to 25mhz fsb only. The clock is zip-tied to the board, it reads 25mhz. That is something that would need to be replaced for any fsb upgrades.
