First post, by kanecvr
Hi guys. I'm having trouble trying to get emm386 to work on my socket 4 machine. It displays "insufficient memory" when starting up... I made sure to load himem.sys in config.sys (DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFF) before emm386.
What I tried so far:
- checked memory - 584k of 640k available
- removed shadowing in BIOS
- tried other memory modules
- tested memory with memtest (OK)
- changed L2 cache chips
- changed TAG ram
- verified L2 cache with cachecheck and speedsys (OK)
- disabled L2 cache in BIOS
- reduced CPU speed from 66 to 60MHz
So far nothing has worked. Any ideas?
Reply 1 of 12, by Imperious
How much memory do You have?
PC's from XT 8088, 486, Pentium MMX, K6, Athlon, P3, P4, 775, to current Ryzen 2600.
Reply 3 of 12, by Jorpho
Are you suggesting you only have 584k free after loading nothing but HIMEM? In that case there's probably some other weird option set in your BIOS. Or possibly you have some kind of boot sector virus.
Reply 4 of 12, by kanecvr
I use /testmem:off to cut down on boot time. I removed it and the machine behaves the same. I have 32MB of FPM installed (2x16mb).
That's because norton commander and the CD-ROM driver were loaded into memory. I removed both, and only DOS takes up some memory (very little) but emm386 still won't load. I highly doubt there's any virus since I've used it in another machine where emm386 loads fine. Besides, I didn't use any old floppies or questionable files. There's 0% chance of a virus.
Reply 7 of 12, by Jorpho
By "it" do you mean the hard drive, or what?
The best way to eliminate the question of hardware problems once and for all would be to make an image of the drive and boot it up in VMware. If there's still a problem in that case, then there aren't many other possibilities other than a virus.
Reply 8 of 12, by Jo22
I currently don't use emm386 very often, but I think it could help to have a look at the memory map in MS Diagnostics
(MSD) or to let CheckIt! do a memory test. As far as I know, it also has the ability to display memory usage in base/UMB region.
If noting works, you could try to boot from a floppy (incl. himem/emm386) or to use Qemm or similar competing products.
Reply 9 of 12, by kanecvr
I used the hdd to boot dos on another machine and emm386 loaded fine.
