Windows Server 2008 on old PCs
First post, by computergeek92
Just how bad or good will a single or dual Pentium III Tualatin 1.4GHz system with 4GB or 6GB of memory run the original Server 2008? (Not the R2 version which won't support the Pentium III)
Dedicated Windows 95 Aficionado for good reasons:
http://toastytech.com/evil/setup.html
Reply 2 of 25, by keenmaster486
Why would you want to run 2008 on that machine instead of 2003 or 2000?
I flermmed the plootash just like you asked.
World's foremost 486 enjoyer.
Reply 3 of 25, by feipoa
Windows server 2003 and xp pro sp3 run really well on my dual tualatin 1.4 ghz with 3.5 gb of ram. Is server 2008 still receiving Wimdows updates?
Reply 4 of 25, by FFXIhealer
Yes, server 2008 will continue to receive support from Microsoft until 14 January 2020. But that's beside the point.
Why would you want to run a Vista-based OS on such under-powered hardware? The OS ALREADY takes forever to boot and runs rather slowly. I can only imagine how slow 2003 would run. I've seen a 2003 server with my own eyes ... God-awful slow on the console side, fairly responsive on the network side (background tasks and share folders).
Reply 5 of 25, by computergeek92
Support for longer file names. I have a ton of files backed up and it's annoying to have to rename the files at times. I've had problems with XP based OS but not in Windows 7. Server 2008 is based on Vista, so I'd imagine it would be free of the problem as well.
Reply 6 of 25, by Trank
Why do you need those backed up files on a Server 2008 PC? Cant you get those files on another Vista or newer PC? I would think if you really needed it you would rename such files even though its a pain.
I know everyone is saying the same thing and all. But it would save you lots of pain in the future. P3s don't even have SSE2 or newer. Its going to run like a turtle, and in the end you will just get fed up with the slowness im sure.
Reply 8 of 25, by DosFreak
https://mspoweruser.com/ntfs-260-character-windows-10/
If it was me I'd use Linux on that hardware over server 2008.
If Windows 2008 Standard 32bit you'll be limited to 4gb. I remember seeing an unofficial patch for this somewhere.
Windows 2008 Enterprise 32bit supports greater than 4gb assuming the hardware supports it.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 9 of 25, by gdjacobs
GPA wrote:
If longer paths is all you need, why no switching to Linux? Ubuntu Server will run like a charm, esp if you do not run Xs there.
For this purpose, FreeBSD based FreeNAS is what you want. Pre-packaged, appliance type install. Robust disk storage. Good performance. If you want more features, go for something like ClearOS which integrates things like email and firewall into the same box.
Reply 10 of 25, by GPA
could not agree more
Reply 11 of 25, by chinny22
Going from another angle why not just stick with Vista or 7 If its for simple file sharing?
It still supports 2 CPU's and you don't load up the unneeded server related services.
Reply 12 of 25, by keenmaster486
Windows 7 on a dual Tulatin 1.4? How well is that likely to work? (I don't even want to think about Vista).
Reply 13 of 25, by chinny22
Not great but better then 2008 I would think.
I wouldn't want to use the PC, but simply accessing shares off it from other computers may not be so bad.
Reply 14 of 25, by computergeek92
I want to be able to play around with and use my files, so Windows is a must have.
Reply 15 of 25, by computergeek92
What are Xs?
Reply 16 of 25, by computergeek92
I'll probably stick Windows XP on there and call it good since all it needs to do is move and store files and have compatibility with them. Renaming a few long named files can't be too bad after all.
Reply 17 of 25, by gdjacobs
So, you need to be able to use it as a workstation as well? If so, probably Windows XP/Vista will be sufficient for your needs.
Reply 18 of 25, by DosFreak
What are Xs?
A GUI. If just a file server then all you need is CLI.
Reply 19 of 25, by FFXIhealer
Yeah, but having a server running only in Command-Line Mode is super-scary to most people. I've known plenty of IT pros who are intimidated by CLI-only. But it's wonderfully compact and efficient that way. The GUI takes nearly 4x the CPU power and over 10x the system resources (memory) to run the same functions with a graphic interface.
Where did I get that from? Well, I'm studying up to take the Server 2012 R2 certification exams and 2012 has a CLI mode and a GUI mode and you have to know the difference between both to pass the test.
